Topic: Not a fox question.... (Read 2424 times) previous topic - next topic
Because my car is certainly death, i have to do another things with my father´s truck. I guess this is easy. In the front right wheel there are a very sharp noise when he turns in that side, or when we are traveling at a sinous road. It´s constantly and never goes......(until the truck is off)
  i Guess this is concerned with the "sealed of life suspention components of ford"....
 The truck is a f-150 2001
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: Not a fox question....
Is it a constant "growling" or "moaning" sound? Does it only happen when the truck is moving? If so the wheel bearing is likely at fault, or the tire itself is scallopped. Look at the tire tread and see if you can find flat spots
Well, the sound can appears when the truck is off, no moving, only turning the wheel to any side or also when someone "jumps" with the truck.......
1989 F-200 V8
1996 Explorer V6
2001 F-150
Perhap's it's some front suspension bushings, control arm bushings/ball joints maybe.
