Topic: More parts, more questions? (Read 4021 times) previous topic - next topic
Where do I get 55/65/75's? How big should I go? Where do I buy a TwEECer?
Check around on TF.
They're too busy fighting one another to give me any help, I already asked them. Some are telling me to MAF/MS it and others are saying TwEECer and others are saying I should s the whole thing and stick a stock motor in a notchback Mustang with a Holset. *sigh*
What about the CFI injector route?
Claude has a good point.
You can modify some of the CFI injectors to work. They are 42 or 46# I think for the 5.0's.
I know I saw a few for sale there on TF a week or so ago.
That is your cheapest mild upgrade.  That will give you a little more breathing room.
Quote from: Aerobird Motorsports;127708
You can get it from them direct or through an authorized dealer.
http://www.tweecer.com/cc_order.htm
I have the CFI from my car is you need the injectors. Blue tops are 42# IIRC
Just a clarification, I wasn't clear enough in saying the WGA broke to due to outside cirspoogestances. It wasn't Scott's fault in any way. I just want to pay him to redesign it stronger for me.
Summit box arrived last night! The catch can is a little "under-equipped". Basically, the bolts that hold it down go into the can (can you say "leaks") and there was only 1 fitting, but 2 holes. Oh well, the breather on top and the siphon on the bottom are awesome and it was worth the money. So I'm thinking, plug the intake PCV outlet, run a line from the block where the breather is to 1 hole in the can, and another line from the valve cover to the can. No need for any PCV valves or vacuum leaks. Sound good?
And either Summit or I made a mistake on the gauge, I got a SILVER 0-35 psi Ultra-Lite PRO COMP gauge! MUCH nicer then the one I thought I ordered. :D
And the head is now at the machine shop, cross your fingers...
That's how they're usually hooked up from what I've seen.
I had wanted to run an oil catch can but I couldn't find a good open spot on the driver's side to mount it. Where are you putting yours?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
I'm not sure yet. It's actually a pretty compact little can. Since I have the original airbox and charcoal can gone and the A/C is gone, I might mount it to the passenger front area and just have long lines. Summit said longer lines tends to prevent a lot of headaches. I have to give it some thought.
*sniff sniff* no pics? :(
Hehehe...
You guys seriously want more pics? Because I take one about every 5 minutes.
load us up pally.
Quote from: Aerobird Motorsports;128116
I thought about mounting mine to the pass. side but figured it'd be a pain in the ass with those lines running all the way over to the other side of the engine bay.
Garrett H.
Exhaust sound clip
Another clip
