Topic: fuel pump locations (Read 3479 times) previous topic - next topic
fuel pump locations
I know most of you would say get under the car n look but im curious to get a rough idea where the inline pump is on my 84 mercury cougar with 3.8 CFI... if memory serves properly there is a high pressure pump IN the tank.. and a low pressure "pusher" pump inline somewhere... could anyone tell me where bouts? and also how would you remove the fuel tank sending unit/pick up?
fuel pump locations
Low pressure lift pump in the tank.  High pressure pump inline.
The inline pump is inside the rear pass side subframe rail where the RLCAs attaches to the car, opposite the ler.
fuel pump locations
ok thank you chuck......... btw do u know what kind of pressure just that in tank pump would produce on its own? low enough for a carbed motor?
fuel pump locations
I think that the lift pump in the tank is only 5-7psi. Just enough to get the gas out of the tank and into the booster pump. I'll check what the spec book at work says the lifter pump psi and GPH should be.
fuel pump locations
Dunno of the exact pressure, but my old carb turbo Pace Car was running an EFI tank with just the lift pump and no regulator.  I didn't set it up that way (got it like that).  Seemed to work fine for a turboed 2.3.
fuel pump locations
The '84 shop manual doesn't give a pressure spec for the low pressure pump.
The test proceedure:
1. Remove inlet push connect fitting and line from high pressure pump. (Caution: Raise end of fitting above level of fluid in tank to prevent siphon action.)
2. Connect  hose from the fuel tank to a calibrated container of at least one quart.
3. Place the ignition switch in Run position until fuel pump times out. (About one second)
3. The container should contain a minimum of 1.5 oz. (45ml) of fuel for one second of operation.
fuel pump locations
mk... thank you
fuel pump locations
On the 1989 F-150 300ci EFI of My friend, the second pump (inline) pressure is around 40-45 psi...
I guess is the same for all direct injected engines...
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
fuel pump locations
im lost,, what are you guys talking about,,,,, A SECOND PUMP?
fuel pump locations
Quote from: jcassity;126702
Yes, the first time I see that is on a F-150 pick-up 300 ci fuel injected, the issue was a "high flow pump", but when I go under the truck I hear a pump, that's okay for Me, but not in reality...
The first pump just suck from the sender to the fuel line, and the second raise up at around 40psi to the FI system, I guess when the first pump are sucked by the high pressure pump, there  just a pass trough, or give to the second pump the minimum flow to gave the engine at the idle...
It's just My opinion, and theory, but never scrounger for why...
Best regards,
Dom.
fuel pump locations
are you guys saying my cougar and everyone else's car here has a second fuel pump?,, sorry to sound stupid here but geshhh,,, its news to me.
a standard in the tank bosch presure is about 60psi there abouts.  the regulator loops back the excess dumping 40 on the injectors.
im pretty sure i can see my fuel lines all the way down the subframe until they creep up into the fender well forward of the pass door.
if you are only refering to the f150,, yeah, i was aware of that as well but your first post says different as well as all the replies.
i swear im not going crazy but as soon as i saw your quesiton and the replies,, i felt like i was from mars or something.
fuel pump locations
From the '84 shop manual:
Town Car, Crown Vic and Grand Marquis have one high pressure pump in the tank.
Mark VII/Continental, T-Bird/Cougar, LTD/Marquis and Mustang/Capri have two pumps. Low pressure in the tank, high pressure in-line.
The in-line pump is mounted with the filter just forward of the right rear wheel.
They must have discontinued the two pump system in later years.
fuel pump locations
eric,, this is an interesting factoid,, i think the 84 specific fuel setup needs added to the tech link on coolcats.  i have had two 84's with cfi, one was a v8 and the other was a v6.  I have no knowledge of this,,,
anyone with an 84 model,, can you check to see if your car has this?
84fila,, you should have it also.
softtouch,, have you seen this pump on your car?
i think its good to know stuff when someone complains about fuel issues and most of us would not make mention of the difference this model has.  perhaps the 83 has the same.,,anyone?????
fuel pump locations
jcassity when i get the chance ill check my cougar for 2 pumps to be sure
the 83 tbird/cougar as far as the 3.8 and 5.0 some had pump's on the engine and some had electric pump in the tank... which is why im lookin for the pick up/sending unit from 83 with pump ON engine so i can do this right
