Topic: 351c Swap-pics Of Parts To Do It (Read 16164 times) previous topic - next topic
for the record, the C is NOT a big block... the head fit on a W block, they have a SB bellhousing pattern, they have small main journals... the only thing that they share with big blocks is the overall size of the heads, ports, and valve sizes...  There is one block that does skew the defining line... and that's the "400 FMX", it has all the outside sizes of the 400/351M but has a small block bellhousing pattern on it... not many were made but I ended up with one...
Methos
so the c isn't classified as a big block?
No. They marketed it as a small block with big block heads.
As methos said they have the same bellhousing pattern as a 302 the same mounts and location as a 302. Smaller main journals, deck height than a 351w.
That is correct. A 351m,400m have the big block bell housing and motor mount locations. A 351c is easy to swap except the expensive headers and oil pan to do it. I've even been thinking of a AOD instead of c-6,lowering gears to 4.10. Im sure my car would be faster and have overdrive. But a cheap AOD wont cut it. They are weak even to a 5.0,and need proper mods to make them live.
1999 Trailblazer(wifes rig)
Heres Some py Pics of Engine
Heres a couple pics of the disassembly of my bird. The 5.0 ho lifter setup,header,oil pan,head. I know the engine dept needs attention.
And I havent bought k-member yet,all to come soon with better pics.
:birdsmily:
One More Pic of the 1BDBIRD
Hail the almighty bird!!!!!!!!!!!!!!!!! I love my T-BIRD. LOL!!!!!!!!!
it looks nasty, i see your missing a light there, and i love the two tone trim lol.
I was going to try to keep the stock Bird K-member but I might switch you a tubular for weight and future upgrades...
Methos
Quote from: 1BDBIRD;128360
I like Your hood scoop!!!, I guess I'll make one for one of My spares Hood, and paint at the same time I'll paint My bird,I'll guess I'll paint two others hoods, one straight, one with a scoop like Your, and the TC hood on the car, If I change My mind for any reason, I'll just change the hood, that's it:hick:
Regards,
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
Ya that scoop is off of my 1974 Comet Gt 302/3spd/floorshift. It has been on my 71 Cougar,and now on my bird. I like the way it turned out on there. Was going cowl but everybody has one of them.
How easy and common is that 5.0 roller lifter conversion?
into a cleveland? I have never heard of it being done.
Methos
Keep on with your Cleveland swap! I'd like to see some pics when you get it in the engine bay and compare how much room you have compared to a 460 swap. __ Alan
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Its the same. I measured the 70 460 I sold last year and If I remember right they were both like 27inches and a half or something like that. Money to Power wise I should have done the 460,but the guy helping me build my engine says that 460+hp is about what I be at with Srp pistons,balance,cc the pistons,3 angle valve job,roller valvetrain,ect few old racer tricks. Should haul ass?
If you can get 460 HP out of your Cleveland  then you most certainly will be in the "Kick Ass" territory!!
The great advantage on the Cleveland over the 429-460 is your bird will be about 175-200 lbs. less heavy on the nose of the car. That will certainly help on the launch.
Our big problem we have with the 730 pound 460s we run is weight transfer. So I spend more time setting up the rear suspension and use Moroso "trick' front coil springs for a Fox Body.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
