Topic: 86 ford thunderbird for sale (Read 3854 times) previous topic - next topic
hey guys
i got a white 86 ford thunderbird for sale.
 99K miles
2nd owner
turbo coupe seats and console
grille and headlamp buckets blacked out
taylor wires
blaster coil
msd cap and rotor
accell TFI module
new motor mounts
the car ran and drove great- the last week i had it on the road it developed a stall problem- that was 2 months ago- i havent had time to look at it. it has a irratic ignition pattern code- im beleiving it to be the pole peice in the distributor since i swaped TFI modules and its still doing this. the interior is all there- the floor shifter just needs to be put in and power seats wired. also have a set of mustang 5.0 headers that will go with it along with a nice set of sunshades- the ones in the car are worn- and the headliner needs replacing. the car has a small amount of surface rust around the rear window
im looking for 600$
the car is located in sicklerville, NJ- clean title in hand
http://rides.webshots.com/photo/2612797270073866237EEUhFJ
http://rides.webshots.com/photo/2152116340073866237HrfXQo
http://rides.webshots.com/photo/2952914800073866237hqQJXF
http://rides.webshots.com/photo/2690364870073866237Kdoqdk
http://good-times.webshots.com/photo/2567448810073866237QSSSDn
the engine pictures are befor the ignition system work
and the pictures with no seats where taken in august when i put new carpet in
oh yes and for contact info
email
a_traenkner@yahoo.com
AIM
keepsake211
and if you would like to call my cell phone just email me- i dont check my PMs here that often so email or AIM would be the best bet
first 450$ takes it. i need it gone this week guys i have another project rolling in friday:birdsmily:
350 takes it?
I emailed a friend who is in need of a cheap car (Philly area). No guarantees, but you never know.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
350 takes it?
Lemme ask the wife.
BTW, where did you get the carpet from?
I had a stall problem for about two years. It turned out to be the stator in the distributor. It would fail when the engine warmed up and would refuse to work again until it cooled. Only $60 to replace, but two years to track down.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
im a tech at a GM dealer- and i have a coulple buddys at the ford dealer across the way and they sayed the same thing about the peice in the distributor
so for 60$- plus 350 for the car you can have a nice driver.:D
I don't need another driver as I already have 2, but I emailed my friend (who is on a very tight budget and needs something cheap). He told me he'd check the link out...
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Man I would buy it right now if I wasn't about to sign a lease on a new apartment tomorrow!!!
Claude, How are we going to get to NJ?
:pics-stfu:
 Project Thread with pics
no one yet.......
, you aren't that far from me. If only I had the room.
Sent you an email.
