Topic: double sided trim tape removal (Read 1328 times) previous topic - next topic
i've absolutely had it with the trim on the side of my car.  im ganna shave it tomarrow.  i know that there will be dirt and double sided tape where the trim was.  i was wondering the best method of getting the double sided tape off without screwing the paint job up completely.  ive decided to primer the car very soon so i dont mind a little bit of  on it, but like i have a zippo so i got some ronsonol lighter fluid, and right on the label it says "excellent for removing labels, tar, grease, and oil stains."  you think itd work without screwing up the clear coat too bad?  any other methods or anything?
goo-gone works well, i think wallmart has it?
~John~
If you've got an auto paint store nearby they should carry a special rubber wheel that goes on the end of a drill. It's specially designed to remove that adhesive. I've personally never used it but I know some people that have, and they really like it. It's not expensive either. It's about 6" in diameter and is a putty color.
Quote from: EricCoolCats;124685
They work good they are called eraser wheels. They work good for even pinstripe removal ;)
Quote from: Autocat;124619
think thats my plan right now also
Quote from: SLEEPER T-BIRD 87;124706
think im going to go get one of those! want the trim gone and my pins are messed up.
ah you see, i used my dad's tools (he has everything you can think of on his work van -- he does maintanance on heavy and light forklifts) and i moved out now and all i have is a metric - ase set of wrenches and 2 philipshead screw drivers.  a drill, although cheap, isnt in my budget yet.  goo gone sounds interesting but im worried it might mess up the clear coat.  i might try both the lighter fluid and the goo gone and see which does a better job.  if either one messes up the clear coat im just ganna go ahead and primer it all together.  i got everything to mask it up already.
let me know how it goes man
weather so far has it on hold.  today was nice, tried getting the stereo in it (no luck, dif thread) but tonight freezing rain all the way through till monday so says weather.com.  since i dont have an apartment with a garage im screwed till i get a good week of no rain.
