Topic: Luck? Whats That? (Read 901 times) previous topic - next topic
Luck? Whats That?
so i got my car mostly put together and running today:headbang: .
and i get it off the stands run the gears though and let it run.
Sounds great i might add.
and drive down the long ass driveway and it is doing good from what i can tell. so i get it out on the road and give it some ok then i throw down a little. so its load under the overpass and it revs high.......
ummm shifting time! but no it doesnt shift. so i pull over and run it though the gears again. then go to leave the side of the road and it acts like a 5 speed would with the clutch in and its slowly releasing. WEirD
so i go to turn around it a driveway and go to but it in reverse. What reverse? there is none it wants to go forward. so i put it in neutral or what i believe is neutral and roll out of the drive way. limp back into the spot that my car has found home for the last 2 weeks and that is were it is now.
well things always happen for a reason. Thsi better be a  good reason
Luck? Whats That?
heck, i fix one thing, something else goes wrong. just my luck i guess.
