Topic: I can't decide...2000 Grit Satin or Polished? (Read 9355 times) previous topic - next topic
satin!
polished ownz!
I'm still sayin' polished and satin.........or polished.........or just satin.
here are 3 pics--X
X
X
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
top photo polished outer w satin trx center and cap--middle photo--satin outer w polished center with satin center cap--bottom photo-- satin outer with polished trx center and cap
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Here is some more on car shots--fully polished--oh ,by the way, top photo looks "strange' because I am using Southside Lowers which moved the rear forward 1 inch. That problem will be corrected! --X
X
X
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
What are you doing to get that high polished look?
I spend alot of time wet sanding with 2000 grit paper. I found a place on the internet that sells 2500 grit so that is next. Then I finish off with Mothers creme polish.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
So what would you recommend for polished wheels that aren't quite polished anymore.  Have tarnish from 2 winters.  Best I could do was a nicely shined AND tarnished wheel. :)
well if the cut outs were all the way thought both then i wold stick with the black center and polished lip but since they arent i say full on poilsh
I will tell you what I do. I start out with 800 grit if the aluminum doesn't have any gouges or deep scratches. Use plenty of water. Then go to 1200 grit, then 1500, and finish off with 2000. I will say, the more time you spend on the lower # grit paper (wet-dry paper at the auto parts or paint supply stores) then the better the overall finish will be. I spend a great deal of time with sandpaper but man is it worth it!  Hope this helps.:grinno:
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
I'll be one of the few dissenters and say, Satin.
what are the wheels behind the TRX center?
I think they are billet. Can't find any i.d. marks on them. I got them for $ 20.00 at a swap meet. :grinno:  Alan
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Again....SATIN.... :hick:
