Topic: Layla's New Plan (Read 1113 times) previous topic - next topic
Layla's New Plan
Well, Layla's broken and I'm broke. Hopefully I can pull things together and keep my house. The problem is the machine shop that did the valve-job on her head nicked a valve guide allowing boost to enter and blow the valve seal off. Putting the seal back on did nothing as it would blow right back off under initial boost. This in turn spit out the rear main and caused havoc with the oiling and dual-PCV system. So here's the plan, I'm getting out of the used TBird parts. Completely. It's a royal pain in my rear and I actually lose money doing it. Well, the local junkyard has 2 87 TC's and a Merkur and they want $600 for a complete motor. I might be able to get them to swap me a motor for my used inventory. I can then put the 100% stock motor with a fresh HG into Layla. I'll probably go for the Merkur's because I already took the head off and it looks pretty nice in there. So I'll have a stock motor, including head. The only thing I can't decide is slap my IHI back on, try to salvage the Merk's T3 (needs a center section), or just use the SC50 and deal with it. Matt's TC runs pretty strong with the SC50 and his is all stock, so I may try it. I will of course keep the CAI, 3" single dump pipe, 255HP BBK, Kirban AFPR, and new 35# injectors on the car. Probably stick with the new dizzy, Dyna-Mod TFI and the MSD coil/Taylor wire set-up too. The decision is, is if I DO stick with the SC50, do I run my gutted upper/ported lower/ported E6 or all stock stuff? I just want the car to run so I can make a pass this year and if worse comes to worse and I have to move, I won't have to tow the thing. I'll keep my rebuilt engine and just go through it and do the big valve/roller head later when I can afford it. Opinions?
Layla's New Plan
Quote from: Aerobird Motorsports;121761
Opinions?
You asked.
1984 Thunderbird V8
Layla's New Plan
sounds like a plan man...hope ya get on your feet again soon
Layla's New Plan
Send me all your 2.3T goodies and i will send you good stock reliable parts;)
Layla's New Plan
If I was going to stab a V8 in Layla it would be the AMC 401 from the corner of my garage and the SC50 would need a twin.
But I'm too broke for that.
Sleeper, got any cash? :D I have parts that aren't installed yet! :D
Layla's New Plan
Come on dude. I can understand being out of money and at wits end with me t/c. Just keep at it. I know gotta have money. Anyhow you goota be able to find some sort of JOB up there. You goota do something so you don't loose everything. I would buy some of your stuff to help but Money is tight here too. If anything I have a good bare round port head we could work something out on. Also check over at turbo ford one guy has a bare good trubo head $50+shipp. Anyhow hope things get better.
