Topic: It leaked again. and wont start (Read 5207 times) previous topic - next topic
Dillon.. put some silicon on the pan and put the gasket on the pan first.. so you know your holes are all lined up..put a couple bolts through and stick it up on there..
-Clayton
weatherstrip adhesive works well for all gaskets,just don't overuse it.
Quote from: kitzdnm;121733
think i put too much silicone on the first time and i know it wasnt lined up.
Now its raining, like that matters i have to get it done before saturday so i can pass emissions and get my tags. wont have time to finish it when school starts again
any one know why it wont turn the starter?
disconnected wire? sliced starter wire? battery hooked up?
oh and your leakin problem... do you have the dipstick tube all the way in?
it leaking/ pouring out on the rear driver corner.
battery hooked up and was on charger/starter when i tried to start it.
going to look at starter wires tomorrow
didja clean all your gasket edges beforehand?
and the not starting thing could be your NSS (neutral safty switch)
Quote from: 87thunderbirdBlackJack;121928
where and what is the NSS for. cleaned everything
The NSS is there to make sure you don't start it in gear and drive forward or backward unexpectedly, as for where I don't know!
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
I think it's on the left side of the tranny. Check the connecter, mine was dirty and greasy. Also make sure you lined the linkages up right. You may not be in park or netrual. This would cause the car not to turn over either. Go through th erang of gears and try to just turn the car over. If it turns and it's susposed to be in, say, drive then your linkages are off. Just adjust them and drive away.
Quote from: 84 Fila;121962
on my 88 cougar with aod, the nss is on the driver's side of the tranny, up along the side. it's not very easy to get to. i used a ratchet with a swivel and an extension with my left arm over the passenger side and my right arm through the small area where i disconnected the linkage. no worries as far as it spilling tranny fluid on you're while removing it.
check to see if the reverse lights come on with just the power on and tranny in reverse. if they don't come on, then it IS your nss. also, be careful not to burn up the wire under the dash if it is your nss by repeatedly trying to crank it. i hope this helps some.
+1 on an issue with NSS
Going to look at starter wires and try the reverse lights. see what happens. How would i fix the NSS problem? just get it in the right gears?
yeah, it can be a bitch, but you just need to get it in the correct gears... hell.. run through em when tryin to start it inside the car..put it in a gear and try it.. and go through all the gears and do that.
First see if you're getting 12V at START on the little lb/r wire at the starter solenoid on the inner fender.  If so...look at your starter.
If not...climb under the car and unplug the NSS plug and loop lb/r wire and see if it starts..... that will tell you if there is an issue with the NSS.
