Topic: My H.O. conversion has FINISHED. she RUNS. yep. (Read 8706 times) previous topic - next topic
Reply #75
Quote from: ZondaC12;126032
"maintains its size" what do you mean by this?
Some lers have lets say a 2.5" inlet and outlet but the inner part with the sound deadening material will only have a 2" diameter core for the exhaust to pass through. "Maintaining it's size" simply means that same size ler would have a 2.5" core to match it's inlet and outlet diameters.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
Reply #76
What he said ^
Thrush is owned by dynomax but it's basically the cheapest of the cheap...i would recommend staying away from them if you can afford it.  The dynomax bullets...well, I've heard mixed opinions on them...they will be obnoxiously loud...if you and your local authorities can tolerate it, you should be happy though.
