Topic: Wheel cross reference? (Read 1359 times) previous topic - next topic
i am having a hard time finding wheels for my 86 cougar. is there anything that cross references with it that i can look under that is more current? i know alot of imports have 4 lug patterns, it seems concieveable that one of them might use the same bolt pattern as ours....
[SIGPIC][/SIGPIC]:cougarsmily:
The new cougar and the ford focus are the same bolt pattern but front wheel offset.
Your bolt pattern is 4 x 4.25"
The newer FWD Cougar wheels will fit your Fox, but they will look VERY awkward.
Reference a '79-'93 Mustang for custom wheels.
Quote from: cougarcragar;119623
I don't know if they will without mods - I do know Tempaz wheels will not fit (I tried to steal the alloys off my girlfriend's Topaz way back when I had my green '85 T-Bird). The lug pattern is the same but the hole in the center isn't big enough to fit over the fox hub. Of course Contour/Cougar wheels may have a bigger hub hole...
Also, the metric equivalent to 4-on-4.25" is 4-on-108mm (import wheels are usually metric)
I thought about that, Sam. However, do you remember about three years ago when there was a Thunderbird on eBay and it had '99 Cougar wheels on it? I thought I could remember reading that they would fit with no issues... but I could be mistaken.
