Topic: What engine combos you guys running? (Read 6401 times) previous topic - next topic
Re: What engine combos you guys running?
87 5.0 block, flat top pistons w/ ported e7's, ho upper, 19 lb injectors, adjustable fuel pressure rgulator, 255lph pump, custom isky cam, 1.7 scorpion roller rockers, 87 mustang computer, K & N filtercharger, hooker competition headers into custom 2.5 inch h-pipe with Dynomax bullet maufflers, TransGo shift kit inside the AOD with an A servo,  7.5 rear w/3.27's and richmond gear full locking unit and CHE upper/lower control arms.  All this with a good amount of weight removal and the A/C removed
Quote from: lowcat
Have you gone through emissions yet, or do you know a way to cheat? :evilgrin: I have to get mine done by March, but I need to fix some egr  first.
Emissions??  whats that??  lol :dunno:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
1993  HO Mustang 5.0, t5, and 3.55 rear out of a TC
The engine is basically a stock 5.0 with a Cobra intake and a Pro M MAF
1988 Thunderbird
5.0 HO, t5, TC rear, TC brakes, etc. - Gone
5.0willgo: where the hell is Rising Sun?
its all in my cardomain :)
Quote from: Tbird232ci
You have been there. Cecil County dragway is in rising sun.
oh....neat
Next motor is a '94 351 with a trick flow stage 1 cam, stock E7 heads till I can afford the AFRs, Stealth intake, speed demon 750, hooker full length swap headers. I will go with EFI later but the intake and injectors will run me over $700 so I'm going to use the carb stuff I've already got off of an older car that I kept some parts off of when I sold it.
-5.0  stroked to a 347 10.7:1 compression, balanced & beautiful
-89 moostang computer
-trickflow track heat o-ring heads
-trickflow track heat intake
-trickflow stage 2 cam
-aramotive fuel rails & pressure reg.
-255 high flow in tank fuel pump
-42lb injectors
-headman longtubes
-MSD pro billit distributor
-MSD digital 6 ign. box
-TCI converter (3500 stall I think)
-mustang 8.8 3.73 gear
-a bunch of other stuff
keeping it streetable :)
1987 cougar XR7 347 stroker FRP BOSS block 328rwhp 10.89 1/4mile @126mph ..so far..
2005 F150 5.4 vortec supercharged @15psi water methenol injected 450rwhp 14.0@98mph on 22's
Quote from: TrickFlow347
-42lb injectors
-headman longtubes
Did you even put up any pictures of that compleated? I dont remember seeing any
Quote from: foxford
Cool!  Someone else going with a Carb for now... EFI later.  Just on a much higher scale than I with my measly 500cfm.
  yea, I put them up in users rides right after it was done, only engine picts tho, Im not brave enough to show the whole car. :grinno:
