Topic: Difference between HO and SO Accessory Brackets? (Read 2615 times) previous topic - next topic
I thought the LSC had a different alternator bracket.The alternator looked a lot bigger on the LSC I got my engine from.I may be wrong,but I remember the alternator being wider between the two bolt holes that mount the alternator.
What set of brackets should I use on a CFI 5.0 car? Stang then?
Either way 84fila,Stang or Bird/Cougar.Stang brackets are all over E-Bay,and there are probably more of them out there than the Bird brackets.If you don't have a/c,get the Stang steering pump and the FRPP a/c eliminator.Very clean look,and do the 3G upgrade while you're at it.
Aight, thanks Vinnie and sorry to hijack the thread.
Yes Vinnie the Lincolns used an 8" alternator bracket and the cat/bird/stang used 7".
An easy 3G swap for the 8" brackets is one from a 3.8 taurus.  You have to mill down the backside of the smaller ear on the alt but thats simple work.
That's what I thought.I have two or three of those 3.8 alternators and a nearly new 3.0 alternator as a backup to the one I'm using just in case something goes wrong.It's been great for a year.I gather up 3G's any chance I get.I had about 10,but I'm down to 3 or 4.The 3.0 3G stays with me.
  Hey Fila,I don't think anybody minds the hijacking,it's all about helping each other.
