Topic: Hello from newbie (Read 2088 times) previous topic - next topic
Hello from newbie
Yes, I have the cam,injectors,and intake from the lsc and the computer from a speed density Mustang Gt. Is that a problem?
If you look at the picture of the engine compartment you can see the firing order wrote in permanent marker. pretty cool eh!
I know that it is not the map hose, I have tried different maps and it didn't seem to make a difference. I've got good vacuum at the map.
I need a right hand inner turn signal.(between headlight and grill). I can't seem to find one anywhere.
Hello from newbie
Quote from: thunderblue;120182
got one that is resealed but not yellow. 5 +shipping with right pass or driver send a PM or email cougar86_89@yahoo.com
Hello from newbie
Not your problem, either EEC will run a Stang or LSC HO just fine...
If it's as rich as you say it is, you should be getting KOER and CM codes...
