Topic: 5.0 TC swap (Read 9367 times) previous topic - next topic
5.0 TC swap
Quote from: CougarSE;116377
Found a truck flywheel localy for 20 bucks!  Problem solved for 20 bucks!
Seems to be the going rate these days.  ;) :D
hahahaa, glad you got what you need.  Hope everything goes together just right for ya...
1984 Thunderbird V8
5.0 TC swap
Quote from: 46Tbird;116101
As for the driveshaft, I know that all T5, AOD, and C4 cars can interchange (they all use a 28-spline output shaft).  The trans lengths are slightly different, but the difference is made up by the slip yoke on the DS.  Are you sure your stock DS won't work?  I don't know what the A4LD (?) output shaft spline count is, but I bet it's the same as the other transmissions.
A4LD is about 4-5" longer than the other transmissons...
