Topic: T3/Downpipe Problem (Read 3151 times) previous topic - next topic
T3/Downpipe Problem
After the turbo on the INTAKE side....
I don't know what you had taken apart, ect.  So it could be anything.  The exhaust leak is not going to cause this issue.
T3/Downpipe Problem
Well i replaced the head, so alot of things were taken apart.  I'm thinking it might be between the head and the lower intake-I did not replace the gasket there... I reused the turbo to manifold metal gasket.
T3/Downpipe Problem
It's almost one you'd hear I would imagine.
Check your TPS and run codes.
T3/Downpipe Problem
Ah, enlightenment.  I guess I was so excited that the car ran that I failed to hear the windstorm coming from my engine.  I'll get right on that...
T3/Downpipe Problem
As for the DP problem, it's almost as if the downpipe has a larger diameter that the down elbow on the turbo.  Is this possible?  It fit the IHI fine.
T3/Downpipe Problem
The DP's on the IHI's were 2-1/2", the DP's on the T3 cars were 2-1/4".  So yes, it's possible, but folks swap the IHIs for T3's all the time.
T3/Downpipe Problem
Ok.  I knew people swapped these turbos alot, I can't believe noone ever's acknowledged the problem (I guess noone has ever had much trouble with it).  I'll have to find a gasket or something I guess.  I might get a 3 in DP from Stinger...
T3/Downpipe Problem
Well I got the car on the road last night.  Yet the battery has been acting up and died, I'll have to stick the charger on it later...  On to another gremlin: the turbo will only spool up to about 6 psi and then it just drops off--it doesn't hold at 6.  It will spool up to 6psi and then just cut out...Not sure why?
