Topic: turbo coupe rant :( (Read 6237 times) previous topic - next topic
turbo coupe rant :(
Quote from: Tbird232ci;115096
5 minutes to spool down?! HA! I have had turbo cars with the intake off running, shut the car off, and in less than 5 seconds, they stopped spinning.
Then your bearings are junk.
Quote from: stuntmannick;114937
You are wrong.
And so are yours.
1984 Thunderbird V8
turbo coupe rant :(
found this, http://cgi.ebay.com/ebaymotors/Garrett-t3-t4-turbo-gt35r-gt30r-turbonetics_W0QQcmdZViewItemQQcategoryZ107058QQihZ016QQitemZ260055799486QQrdZ1  I'll probably get flamed for it though.....
turbo coupe rant :(
Quote from: 46Tbird;115102
Then your bearings are junk.And so are yours.
I guess my brand new SC50 was junk.
How much experience do you really have with turbo cars?
turbo coupe rant :(
5 mins is a joke, 1 or maybe 2 TOPS in ideal conditions.
turbo coupe rant :(
is there any way to connect a V-band turbo to the stock pipe without making any changes to the pipe? maybe some kind of adapter?
turbo coupe rant :(
those cheap ebay turbo's are known for being . No offense I dont think it was your friends fault really.
turbo coupe rant :(
Quote from: turbotuner23cc;118167
I guess you didnt read the whole post then...  he wasnt nice to it at all...
turbo coupe rant :(
Were you in the car with him? How could you let it happen? Grow some balls.
"Anyone can make a Mustang fast. It takes a special kinda of Idiot to make a Thunderbird fast"
Slammed 1983 Ford Thunderbird Turbocoupe 5-speed 2.3 turbo. "Breaking parts as fast as i can put them on"
turbo coupe rant :(
Did you end up winning your turbo?  Honestly man...  if you need your wheels and it gets you back on the road...  **** it buy an e-bay cheepie and go easy on it till you can afford something better...  or just save up for a v8 conversion ;)
turbo coupe rant :(
Reply #39
sort of on topic here,,, has anyone ever explored the option of the standby diesel generators out there.  The larger ones usually have turbos on them.  Could this be a possible source of turbo's.  I had my first up close/personal experience with them while over in iraq working around different stuff like this with the army.
turbo coupe rant :(
Reply #40
no. I read the post and I am not trying to be mean at all man so please dont take this wrong. Do a search on turboford and the net in general about the scorge of cheap ebay turbo's. I have seen  videos of them on the dyno literally blowing the heck up! you are lucky you just lost the oil seals. I have seen a video of a guy with his car running and the compressor blade would spin a few times and stick....spin and stick. Poorly machined housings. A little romp should not have killed a good turbo.
Let this be a lesson...if you took the money you spent on a cheap ebay turbo + the money spent if fines and the general hassle of downtime you could have bought a nice properly machined turbo to begin with that would still be working right now and have many miles to go
turbo coupe rant :(
Reply #41
Quote from: turbotuner23cc;118204
this is where I am now, installing a garret .60 .63 for the time being and saving for something better.
turbo coupe rant :(
Reply #42
cool...like i said please dont be offended by my post. I am not here trying to be a smart ass. I will admit I have been tempted by those cheap turbo's even after all the  I have seen. I tend to think "maybe I will get lucky" I once bought a rebuilt t3 center section and I used to for about 1k miles and took it off to use something else on that car. When I went to use the rebuilt T3 on something else...it smoked like a freight train :shrug:
turbo coupe rant :(
Reply #43
Quote from: jcassity;118190
I knew you were in  the service, but I missed the going to Iraq part. I was also over there with the army, in Samarra.  To answer your question, I think they are a bit big for our appplication. I'll have to look up the specs again, i think I might have a decent 10 manual around here I can consult on that.  Plus, does it even have the  like out cars have?  They sure cant be anything to special, because I saw a lot of them burn up easy.  Granted, these things were sort of working in turbocharger HELL (130 + degrees, constant running, ect )  I'll get back to you when I know more!:birdsmily:
88 TC, Lots of Mods.
turbo coupe rant :(
Reply #44
Quote from: Birdman;118220
i've always wondered the same thing.
