Topic: Misterious piece of copper-something under the Ford's hood... (Read 2520 times) previous topic - next topic
Have you ever wondered what is this piece of copper-something under the hood of all 70's and 80's Fords?
I have it in my '87 T-bird  and '77 Granada. In both cars it looks the same and it's placed in the same place. What is it?
I always thought it was some kind of ground strap.
Its to ground the hood, why it needs to be grounded is beyond me.
Scott
ground strap as stated above
Doesnt the hood light only have the + wire going to it? Then again, that ground isnt even touching the hood when its up. I would think it would ground just fine where it attaches to the rest of the car.
its a hood ruster...  remove it lol  on both of my 79 cougars there is a big spot of rust where it was riding.
It is the backup ground strap for the hood light. As stated there is only one hot wire going to the bulb. The housing for the light assembly itself is the ground, so as soon as it's bolted to the hood, it's grounded and the light works only when the hood is up. But since the light also turns on and off via an internal mercury switch, if the switch goes bad or gets stuck, theoretically the light would constantly stay on under a closed hood, without a backup ground.
However...I've had the mercury switch go bad, and never got the light stuck on, but it drained my battery overnight regardless...so is having the ground strap really worth it?! LOL
Also...if you polish that piece it looks really sweet. ;)
I don't have the light under my hood ( ripped off by ex owner?) so can I take it off?
Quote from: EricCoolCats;113155
You didnt....
Quote from: Also...if you polish that piece it looks [i
really[/i] sweet. ;)
Runs out to get the dremel and polish...................
I thought the ground strap was to keep the ignition and alternator electrical noise contained and out of the radio. The light should ground just fine through the metal hood and hinges. I can't see how it could possibly be a "backup ground" for the light, since it's specifically designed to do nothing with the hood open, and according to my wiring diagrams, the mercury switch controls the power side, not the ground.
Quote from: MasterBlaster;113227
It does that too. ;)
-oh....grounding strap!  i gave it to my wife and told her you get a free cheese grater with every car purcahse...LOL.....
I second that.
Shop manual calls it the "hood bonding strap"
It is one of two "Radio Interference Suppression" items.
The other is a "Dash to Engine Ground Cable".
LOL You guys will believe almost anything I say, won't ya. ;)
Ford actually had quite a few tricks for radio noise suppression. That hood ground strap was one. There is the rear ground cable from the firewall to the block. On 5.0 cars, at least, there is another ground cable from the block to the framerail. Ford also created an inline shunt wire that could be installed on cars that had excessive whine through the radio (there are a few NOS ones floating around on eBay regularly). The factory plugs, wires, cap and rotor were all carefully mixed to reduce noise. In general, Ford engineers did a pretty good job in isolating any alternator whine. I've never really had any issues with any of my cars and the electrical noise, except when I had a bad factory plug wire once.
As for that hood strap...do you need it? That's your call, really. It's sort of a backup ground. I've never seen a need to remove it on a stock car. I did leave it out of the convertible's engine bay after I got the fiberglass hood.
(P.S. The part about polishing that strap is true, though...I did it. Looks like pure gold. Real pain to keep polished though.) ;)
