Topic: avatars (Read 8319 times) previous topic - next topic
avatars
will we get avatars?
avatars
They're already enabled. You should be able to add them in the user control panel.
avatars
Quote from: Thunder Chicken
It doesn't have the option to add one.
avatars
Hmm...
It may be because everyone's a "junior member". I've enabled them in the control panel, and I've got one, and Eric's got one...
I'll look into it further and see what I can come up with
Re: avatars
Testing my avatar:
Re: avatars
cougars2Go  - that's a signature, not an avatar. The little engine up by my username is an avatar.
I have just set the thing so that if you have two posts you're a "Member" instead of a "Junior member". Hopefully this makes it so you can add avatars and have custom titles, but I won't know until one of you tries it. So try it already!!!
Re: avatars
That's cause you guys have like 17,000,000 posts already.
I only have 2 (or is it 3 now?).
I am, I am! But it doesn't like me.  :(
Re: avatars
testing 123
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: avatars
I know.  It didn't work and I saw your post on the other board about needing two posts so hopefully this post will allow me to use avatars.
Testing my avatar AGAIN.
Re: avatars
Ok, I was allowed to upload an avatar but the size limit is smaller than Cougarnuts.  The avatars over there cannot exceed 100x100 pixels and the file size is small too.  Can we change that to match over there?
Re: avatars
OK, got it fixed. YOu can now upload avatars and have custom titles, as evidenced by the ones I attached to this temporary user name. I'll fix the file size thing in a minute.
Re: avatars
OK, done. It's all spiffy :D
Re: avatars
Quote from: avatartest
Thanks! :D
Re: avatars
Yay, it works!!  :D
But, with the avatars being stored there, how am I supposed to screw with Manson's dancing banana every few days???  :rolleyes:
