Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148640 times) previous topic - next topic
Reply #210
your carb bowl is empty probably,,, dont forget to pump the pedal to start.  The pump on the carb likes that a little:hick:
yeah,, if you spray gas in there it should atleast hit.  check spark like you said.
Reply #211
So how do you "prime" the carb? Just turn the key, let the gas soak/fill the carb, then pump it a few times and turn it over? I'm about to check all the wiring and conections. Does the Duraspark have to be grounded to produce spark? And can it start without the V. adavance hooked up?
Reply #212
theres something in the carb called an "accelerator pump" that shoots a little gush of fuel in when you hit the gas. so if theres none, you can pump it a few times (good and fast) and itll prime it, like pushing the primer ball on a lawnmower.
you could also spray starter fluid/carb cleaner/wd-40/bug spray something burnable :hick: in the carb, have someone crank it over, once it fires, continue spraying for a few seconds, stop, and see if it goes on its own. if not spray some more. if it wont run without you spraying theres a fuel delivery problem. but usually you only need like 3 seconds worth of it running on whatever youre spraying in there and then its fine.
nothing like the simplicity of a carb'd engine. :headbang:
Reply #213
It's a double pumper, so pumping is needed. My question is how fast will it fill with gas? And i'm not as much sure as it's a fuel problem as a spark right now.
Reply #214
give it 3 pedal pumps.. and turn key. repeat.
Reply #215
I'll try tomorow. It's -3 outside right now.
Reply #216
Carb cleaner and WD-40 aren't flammable enough to kick the car over.  Use starting fluid if you use anything.
Reply #217
Tomorow, if I feel like freezing my ass off. Suddleny ripping off a working system in the middle of winter doesn't look like such a good idea...
Reply #218
Quote from: Ifixyawata;127607
well all i know is you work with what you got in a pinch and the only time i had to use wd was with my snowblower and it was all i had. helluva smoke cloud but she fired right up :hick:
started the 38 buick with OFF! bugspray once cuz i was too lazy to walk over to the shelf unit on the other side of the garage that had carb cleaner. :hick: :rollin:  no im not kidding about any of that. the bug stuff was closer and im  lazy sometimes. awful...
Reply #219
may not be as flammable, but they still are flammable
Reply #220
Lighting shiznit/blowing stuff up is one thing. Starting the car is another. Carb cleaner/paint cans/bug spray is better for flamethrowers IMO
Reply #221
u make due with what u have, i saw a guy once, drive his jeep across a finish line with his friend under the hood spraying crab cleaner straight in, cause his fuel pump failed.
Reply #222
I have starting fluid, just to cold ot for today. Tomorow I'll work on it for sure.
Reply #223
can't wait to hear if u get her running or not.
Reply #224
It's not a matter of if bro, it's when. I still have everything to go back to CFI if it doesn't work. And I have access to more then one working carb. It's just how much money I wana sink in and how badly I want it. Right now I want it done, but not enough to work in a below freezing garrage.
