Topic: Rear Suspension ( member discount) (Read 3074 times) previous topic - next topic
Quote from: badbird;110938
these are not only for drag race they are just replacements that have better geometry and fully adjustable. if you guys are happy buying OTS then fine I will no longer pursue the deal.
Ron
We're not trying to be smartasses or screw your deal or anything - we just want some specs on the control arms. Believe me when I say that any new products for these cars is a good thing. Just give us a reason to choose them over others.
Quote from: Thunder Chicken;110979
BINGO!!
Yeah what do you mean by they relocate the upper arms "further out?"
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Here's why these Upper Control Arm kits are better than leaving the stock suspension geometry alone:
Question: Was the Fox Chassis designed for drag racing from Ford?
Answer: No. The Fox suspension was designed for driving around town in comfort and a little bit of handling. Ford had no intentions of designing the suspension for maximum straightline performance which is what you want from your Drag Car.
Ever look at a true 4-link cars suspension? When you look at a tube chassis car equipped with a 4-link you will notice that the lower control arm is horizontal with the ground while the upper control arm is angled down. These angles are critical for locating the Instant Center for Drag Racing for the best hook and best stability which is why there are so many different holes to choose from. The Instant Center position DOES make a difference.
Quote from: badbird;111269
Question: designing the suspension for maximum straightline performance which is what you want from your Drag Car.
-i thought you stated earlier these werent for drag racing???
Ron
they are not ONLY for drag race they are street strip capable.
if you want to run them on the street fine. if you want to race fine.
