Topic: Winter projects (Read 6736 times) previous topic - next topic
Winter projects
I'll be focusing on two main ideas:
1. Making sure the '86 is reliable and solid, while installing small performance modifications.
2. Preparing it for a paint job in the spring, which would have me ready to go for Carlisle and Cat Jam.
Winter projects
Fix my hung o sheit.
Winter projects
Quote from: Tbird232ci;112026
Your car dosen't look that bad.
Winter projects
Quote from: thunderjet302;112035
He's good at trickery through photography.
Honestly though, the only issues I know of with the car is the clearcoat peeling that you can never see in his pictures.
Winter projects
I am now revising my winter plan. I need paint/body work and some brake work and a full tune up. After that Mine should be done for the most part. Untill I break something or buy parts I don't need.
Winter projects
a rebuilt engine for the mustang (stock is tired)  but thats late winter early spring. gonna brace the car up and have the stoping power adressed. 4 wheel disc
Winter projects
Start the body work in the 84 T/c and maybe some engine compartment upgarades to make things look better.
Winter projects
heres a sneak peak at the project already underway.
It's a 91 Cougar HO motor, that I am puttin an E303 in and GT40 intakes, and noisey gear drives.  Then I will be converting the bird to mass air and dropping it in.
Winter projects
Reply #39
Quote from: Ifixyawata;112044
Bingo. The car is a piece of junk. It has more body work in it than Michael Jackson. Rear 1/4 has been replaced, and so much puddy in it that its not funny. Not to mention the clearcoat peel, the twisted front end, and the caved in drivers door. And thats only the exterior. Looks are very decieving.
Winter projects
Reply #40
Saving up for a surprize... if someone doesn't beat me to it first. :D
Other than that I plan on driving my TC this winter.
Winter projects
Reply #41
Quote from: Tbird232ci;112202
thats what makes it into the badassed sleeper that it is
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Winter projects
Reply #42
Quote from: 1WLD BRD;112101
I thought you were sellin' that car?
Winter projects
Reply #43
Cool but, uh, why didn't you paint the valve covers too?
Winter projects
Reply #44
I did. they aren't installed yet.  those are the  ones just to seal the motor so I didn't have to tape much.  I will post a pic of the motor mocked up and all painted, this weekend for you.
I was triing to sell the bird, but since nobody on here seems to be intrested in it (what a shock:sleep: ) I figure I might as well make it haul ass.:birdsmily:  And keep it around.:grinno:
