Topic: 2.3 Turbo - Head Compatibility? (Read 4309 times) previous topic - next topic
There should be locating dowels.  I've not had any problems reinstalling heads w/out guide studs.
You can get TTY 6-point bolts at AZ and the like if you want to get new ones, but the originals should be fine.
Oops. In that case, the dowels must have gone off with the head to the machine shop.
I hope I can get the head back onto the block without damaging anything. It's much heavier than I thought it was.
The good news is that I'll have my Dad to help me, and I've pulled the radiator and fan. I can actually stand inside the engine bay and do this thing.
Thanks for the replies, folks. Especially Chuck... you clearly know what you're talking about, and I really appreciate the help. I've been driving Fox Cougars for almost eight years, but I'm truly hooked on the turbo 2.3.
:D
There should be a dowel on the front and back.  YOu can tell by looking at the bolt holes which ones they are.  You will need them to locate the gasket as well.
You can get new dowels form fel-pro. The box I have says they are for Ford 4, V6 122,140,230 engine 1974-1986 It also says replaces no D4FZ-6A008-A  O.D. .683 length .755 Oh yeah and the part number is ES74011 hope that helps you find the dowels.
