Topic: Dash Lights (Read 1648 times) previous topic - next topic
Dash Lights
Ok so i figured out why i have no dash lights.  The mechanical oil pressure guage i had was leaking inside the car shorted out my cluster (fixed) but it got down to the dash dimmer on the headlamp switch i can get it for $70 from work here but thats a little steep anyone know if i can repair it or get another one for cheap.
PS i already tried all the syards in town they keep crushing all the fox t-birds and cougars they get.  Lots of MN12's and stangs tho s.
2004 Impala
Dash Lights
So...you had oil passing through your firewall? That's like, not safe...
Mark VII's used the same headlight switch that we had, at least from 1985-ish on up.
Dash Lights
For a street car, use an electrical gauge.....
Dash Lights
Its a mechanical reostat with wiper arm so you could try a spray can of electronic cleaner and then blow it dry.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
Dash Lights
Quote from: EricCoolCats;108875
So...you had oil passing through your firewall? That's like, not safe...QUOTE]
Yeah like i havent heard that before lol.  I fixed the leak, so you think i can just clean it?
2004 Impala
