Topic: Lowered my 87, but she leans (Read 4302 times) previous topic - next topic
Quote from: TBirdNutt;108763
When you cut springs, you will almost always change the temper of the spring material, which will have an impact on the spring rate and strength of the metal.
"Tempering" a helical spring has no effect on its spring rate. It will change the yield strength and at what point the spring will "set".
Quote from: 46Tbird;108841
Who gives a shiznit how many Gs it can pull...
i do. :screwy: :laughing:
lol.
Then I'll let you know how it does...  :pbb:
1984 Thunderbird V8
that it! I'm slamming the 87tc andno one can stop me!!!
So any time you want to change your car's ride height, you need to buy a new $200 set of springs?  Please.
That's what coilovers are for. :grinno:
So he would spend the money on hardware to assist a lowered vehicle, but not on the springs themselves? Not that I'm against cutting springs, even planned on doing it myself, but I figured if I got to spend the money on the other parts I may as well cough up the dough on the springs as well.
BTW, the Mustang looks good. Like the wheels.
Quote from: gumby;108895
Me too. :)
Quote from: 86caprirs;108782
I guess I could change the spring rate but the spring was the same size thickness at the bottom of the spring to the top.
Spring rate isnt just determined by thickness, but by the amount of material in a given distance. By reducing the distance, it effectivly alters the spring rate.
It's probably not the hot setup for autocrossing or tire wear but it looks cool.  Who gives a shiznit how many Gs it can pull...
Yeah...cutting springs is awesome, since everyone here drag races, and drives straight only! No turns for me!
I don't drag race mine because I daily drive her.
:burnout:
Quote from: Tbird232ci;109441
It lowers the car and stiffens the spring rate.  Yes, that's what everyone does for drag racing their Fox cars.
Some of you guys are.... funny.
1984 Thunderbird V8
