Topic: 351W C6 to a 351M (Read 2350 times) previous topic - next topic
351W C6 to a 351M
my buddy wants to know if the c6 from my 351W will bolt up to his 351 mod
thanks a bunch
351W C6 to a 351M
nope, sure won't.
351M/400 share the bell pattern with 429/460
351W C6 to a 351M
Quote from: FordTruckFreeek;108295
nope, sure won't.
I beg to differ.
mid 70 full size LTD, T Bird and Cougar have 351M from factory and they do share same bell housing with Windsor family.
The big question is.....
Which 351M does BlackJack have?
351W C6 to a 351M
black jack has a 302 :D
geordans 78 tbird has the 351 mod with the 2 barrel
351W C6 to a 351M
Quote from: KwikFord;108296
I beg to differ.
351M/400 DO NOT have the windsor trans bolt pattern, they have the 'big block' bolt pattern.
Those 70's cars I believe used the FMX with the m's didnt they?
351W C6 to a 351M
All 400's and 351m's had BB bolt patterns.  They came with C4's and FMX's and some trucks had sticks.  The c6 from his windsor won't bolt up.
351W C6 to a 351M
I do know the '76 Ranchero GT that i used to have had a 460 and a C6 in it...would do a one-wheel-peel as long as you kept your right foot planted, too :cool:
And...as mentioned a time or two in this thread already,
351M/400 ARE THE SAME BOLT PATTERN as the 385 series "big blocks" (429-460)
In fact, distributors will interchange as well...
Trust me, they are the same! I've swapped a 460 into a 351M truck.
Was a post on FTE sometime back...i think the gist of it was that the FMX was a car only transmission..and I think by 1978 that big ole Tbird most likely woulda had a C6 anyway...
i could be wrong on the trannies tho..
351W C6 to a 351M
There were a few early '71 400's that had the small block pattern, but they are few and far between... All 351M have the BB pattern...
Quote from: FordTruckFreeek;108303
My Pop had a '79 Cougar 351W and it still had the FMX tranny... Wifes aunt also had a '79 with a 351M that had the FMX. My guess is they went with that tranny because of the removable bell...
351W C6 to a 351M
both of my cougars 302 and 351W had the FMX  the 77 bird had a 400 and C6 and the 351M cougar had an FMX
I have a big block bell for an FMX if interested
351W C6 to a 351M
Quote from: 88turbo;108342
Yep, I think I need to do more reading on the transmissions...I will admit that's one area I'm not as knowlegdable on..:dunce:
351W C6 to a 351M
i got a 351m in my truck from a 79 cougar and it bolted up fine. up untill now i was sure the 351m/400 had the bb bolt pattern...?
351W C6 to a 351M
Quote from: Nate;108368
They do.
What motor was in the truck, a different 351m?
On a different note, I've seen a lot of people swear AT the 351m/400 because they over-revved it, and tore it up, not realizing it is a low rpm, torque producing engine. Parts aren't as common for them as a 351W, let alone a 5.0, but built right, they'll out-pull a modern 351w everytime.
Kinda peeves me to see people yank them out, and set the truck up for a 351w, when a 429, or 460 will bolt right in. (after changing mounts, of course)
But yes, for the LAST TIME, 99.9% of 351m/400 engines have the "385" series bellhousing bolt pattern.
351W C6 to a 351M
Quote from: FordTruckFreeek;108370
My buddy wanted to do thast in his current project 78 f250, I cuffed him and threatened his life if he pulled the m for a 351w. I think it werked
351W C6 to a 351M
yeah, im keeping the M because i want to do a fuelie 460 swap with its manual transmission.
