Topic: gear ratios (Read 1727 times) previous topic - next topic
gear ratios
what are the gears in a 8.8 out of an 86 mustang gt and the 7.5 of an 87 3.8 tbird, would it be a good swap
gear ratios
what tranny did the mustang have?
i believe its like the turbo coupes
Auto: 3.55
manual 3.73
8.8 would be better off
gear ratios
mustang is most likely a 2.73:1 and the 87 7.5" tbird rear probley has 3.27:1 to make up for the tastic power of the 6cylinder.
gear ratios
most mustang's I have seen were 3.08.
gear ratios
My 88 3.8 bird had 3.08 in its 7.5.
gear ratios
depending on options, trans, and location of vehicle build.
Mustangs could have 2.73, 3.08 or 3.55.
gear ratios
mustang is a california car with a 5.0 ho and a t5 tranny
gear ratios
whats the axle tag say, post it and somebody, or myself will decript it for you. im almost positive its a 2.73 tho, that was the standard equiptment with a manual car, unless they got the optional 3.08. it was an automatic, probley a 3.27, but i usualy see manual mustangs, so im asuming thats what it is.
gear ratios
Best way to tell is if the car is near you jack it up and roll the tire see how many times the drive/shaft goes around.
gear ratios
Quote from: KwikFord;108206
To my knowledge no 5.0 Stang ever got a 3.55 gear at the factory... The 5 speeds are 2.73 or 3.08, the 3.27 was available with auto, but you don't often see them...
