Topic: Upgrade and/or Replacements (Read 3923 times) previous topic - next topic
Quote from: cougar86_89;108288
i was just guessing price i havent shopped in a while so in my mind things get cheaper as time goes on till i buy them
They have been $200 for as long as I can remember. MM isn't too keen on lowering their prices. But they are worth it. Oh and the spacers are $25 ea.
im sure they have i just cant remember cause i know i couldnt afford them last time i looked
FWIW, i have a bullit/mach1 suspension kit i had purchased for my tbird. (got it new from buyfordracing). PPI sells the springs  shocks and swaybars sepperately at a fair price. i decided to keep it for use in the mustang as a replacement later on. it already has mach 1 suspension in it. the part numbers are the same between both sets for the springs and im sure the tokikos are the same. the only differance is the swaybars. the bullits are hollow while the machs are solid.
id make sure you at least got the matching shocks/struts.
~John~
so those mach springs will work? and they will lower the car right? is 50 a good deal or how much should i try and talk him down to?
Quote from: shame302;108331
Springs have the same part number? Cool! I do know that the Tokicos are different. Mach 1's got revalved dampeners for a firmer ride.
Quote from: cougar86_89;108335
.... I will post my results and you can see for yourself. $50 is a good deal, they normally run around $100 for a set.
well, the bullit kit i got from BFR have the mach 1 part numbers. i suppose its possible they sent me the wrong stuff. the sway bars are deffinetly the bullit ones.
50 bucks is a great deal if they dont have a ton of miles on them. they realy shouldnt only being a few years old.
PPi has them new.
http://www.performancepartsinc.com/suspension.htm
BFR has them as well.
http://www.buyfordracing.com/shop/product_info.php?products_id=458
ive seen them for sale on ebay, corral and the registry used, for realy cheep as well.
~John~
