Topic: Spark plugs...how I hate thee (Read 3225 times) previous topic - next topic
I've had new spark plugs sitting on my work bench for weeks now, I can't get the old ones to budge. Mainly because I'm afraid of breaking the old ones and screwing up my engine.
To my dispense I have 1 socket for spark plugs, and 1 spark plug socket wrench with bendy arm.
As for the new ones they are pre gapped to .052" my car requires .054" will the 2 thousands of an inch really make a difference?
I'm afraid of breaking them, I'm fine for everything else.
Re: Spark plugs...how I hate thee
Well with spark plug socket u can try a wrench on it or use rachet.
try when motor is cold if u feel there to tight try when the motor is hot and see if they can come off then,  Wear gloves and be carefull.
What breaks them is when u have socket on a angle and try and twist.
try to have shortest extion on the socket or a closed end wrench on the socket if u can do so.
Good luck
I understand your hesitations on replacing....I just changed out the originals on my 1988 V6 w/55k miles, it seemed quite easy once I was able to see where they were located!
I wouldnt worry too much about .52 to .54. I put mine in around .45 and it runs fine. they came out less then .35
I just pulled one to check wear as I had changed them 4 years ago on my '88 3.8 Bird.  The setting is .050  (why, I don't recall) and yes, it took alot of effort to free it--I used a short breaker bar on the ratchet and the plug was seized on the socket when I got it out.  The wear was negligible--but we haven't been putting any mileage on this vehicle in recent years.  I do recall seeing (on the old plugs) that the wear was extreme on the stationary electrode and not on the bendable arm (a fooler).  I reinstalled the plug and broke the plastic wiring harness mounting (on the valve cover screw) for my effort(dam).  Also pulled the disributor cap and made an observation: the rotor throws off micro size metal bits that ring its movement around and around as I could see this ring on the cap.  No doubt a good reason to clean the inside of the cap, etc...
Glad I do not have to replace the plugs now as the right bank is a real joy to tangle with.  Also, you find that the plugs are installed at an angle in the block--wasn't used to that from all the years of changing them in older American cars.  Nothing stays the same except death and taxes.
John R
c'mon dude, man up and change those already! I'm buttstuff when it comes to that stuff, so I would tap em back and re-gap em, but thats just me. Plugs are easy to change.
Quote from: MDJ1281
Especially on these cars! Just put a pipe over the socket wrench and use it to multiply the torque you apply on it...it'll come out.
pro-five-oh
I bought some wd-40 cause I still can't budge these ****ers. I'm going to go to my girlfriends house tomorrow and see if I can change them over there cause her dads a mechanic and must have a torque wrench.
someone must have over done it when they were installed.  dissimilar metal issues contribute to the plugs and corrosion.  anit-sieze would be nice in this situation.
with my car, my problem was getting to the plugs,  smog lines or whatever the hell they are got in the way
