Topic: update, aka pic whoring (Read 8033 times) previous topic - next topic
yeah, no problem, i got the g-force open face SA2005 from them(basicly the same helmet).
all we can do is lurk there, if you say t-bird they stop talkin to ya :toilet:
Quote from: gumby;105499
Just because they are jealous ;)
Think thats hard?  Try saying Cougar!  They :beatyoass:
Quote from: Dogcharmer;105496
...can get the same wheel rate control of a 900# + spring with a 375# coil over!
man, i totally skimmed right over the numbers in your post here. are you runnin 375's on your car? if so how do you like them?
i have driven/riden in various sn95 cars with different coil over rates from 300-600#. i plannin to run 400's on mine, but i havent driven a bird w/coil overs.
they have every reason to be jealous, i mean they see themselves around every corner, but wheres the fox luv?? :p
I have 375's on my 86. It's a very (ultra)firm ride but I like it (I feel every painted line on the road, hahah). There is enough compliance so it doesn't skip over bumps but I've got yellow Koni DA's. The wheels  really stay planted on the pavement. I have to be careful about potholes and big dips in the road though.
I couldn't tell whether you have Bilstiens or Konis from the pic (I think both are yellow). My Konis are set up 50/50 right now. Some day I'll probably jack around with the rebound adjustment. they seem pretty good right now so I'm just gonna leave em "as is" until I get it out on an auto x course and drive it hard... then go from there...
Quote from: gumby;105639
i mean they see themselves around every corner:p
I do to in my 87 bird with the standard sprung 4 link in the rear... but not in the 86. I think the Panhard bar and coil overs out back were the cure... Now all I need is a torque arm so I can ditch the stock uppers.
jus to clarify, thats an 86 bird, not a mustang, right?
my shocks and struts are bilstiens from a cobra. i think they may be on the light side for 400's, but i can upgrade them later. they are what i have for now.
It's a Bird...
Most people seem to prefer the Bilstiens over at the Corral. I hear they're pretty bad ass dampers... Plus you dont have to adjust them!
i thought that was the car we were talkin about :drool:
Just wanted to get an update on how things were going for you...Any new pics?
85 TurboCoupe. 306/DartSr's/Vic 5.0 Intake/B-25 Cam/Vortech YS trim/A9L Computer and Mustang Harness/ Pro M 77 MAF-50lb inj/TKO/15X10 Prostars/MMR Coilovers-90/10's-50/50's Chucks shock brackets/CHE Adjustable uppers/lowers. FR manual rack/steering shaft.
92 LX Coupe 306/Gen VII DFI/ No engine /TTI Race kit T-76/Comp cam/ 15X10 Prostars
nope, no new pics. still waitin on more bushings for the control arms. i only had two of these, then i found a better option anyhow. two piece bushings are on the way...
mini update
new bushings are here. man are they nice!
these are the old style bushings that i could make work if i had to
you can see the large single shoulder. i would rather have double shoulders on a control arm bushing. plus they are a lil too long, so i had to trim some off the ends to get them into the Kmember buckets
these are the new two piece bushings
the two piece fits better, has shoulders on both sides, and feel like a higher durometer material. im glad i waited for them, the better fit is worth the cost of the bushings alone, much simpler assembly.
chuck, the number on the bushings is 2511. i am told they are meant for chevy trucks...
Cool.  I have a set of those arms too...just not keen on the balljoint options.  I've thought about modifying them to accept the SN-95 ball joints.  Thanks for the p/n.
is your set TIG'd? i thought about buildin jigs, cuttin this set apart, and buildin a TIG'd set. i still may do that down the road.
i think the balljoints that are used in these are GM parts. yes/no? how much different is the sn95 outer diameter? then we could use sumthin like the X2 if we wanted.
I'd have to look at them again to see what they are.
What I was thinking was more like the MM stuff that has a longer ball-joint ring that the ball jount actually wound up recessed into..so as not to have to crimp the tubes at the ball joint.
Yeah the stuff KB used...at least when I was there was GM roundy-round stuff.
w00t!!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=190040100985&ssPageName=STRK:MEWN:IT&ih=009
three coilover springs for $66!!
they are a lil short. i was lookin for 8's, but i can shim my coil over sleeves up on the strut body if need be.
cheapest i found locally was $40 per coil used(hypercoil) and $36.xx ea plus handling from summit(QA1)
might actually get the front end together soon! :shakeass:
