Topic: changed TB and NOW trouble HELP!!!!! (Read 1274 times) previous topic - next topic
hey guys im in trouble right now. I have a 5.0 standard and i just change dthe throttle body from stock to a 75mm tb and 75mm egr.  When starting up the car sounded liek  couldnt idle and sounded boggy. I tried  timming idling it and it didnt work. Please someone help !!!!  my car was runnin good with the stock 55mm tb . Now it sounds like  n wont idle correctly. What is wrong with it?????
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Did you change the TPS, or are you using the stock one? Did you forget to hook up a vacuum line?
Make sure your TPS is set at .98 volts with the throttle closed and check for vac leaks if you disconected the upper intake to change the TB and EGR spacer. Also a 75mm TB is waaaaaaay too big for a 5.0 SO and even too big for most modded 5.0 HOs. The only time you really need a 75mm TB is when you are running a blower. Most guys with modded 5.0 HOs (H/C/I) run a 65mm TB.
75mm is TOOOOOOOO big take it off now clean it up and send it back. I think it will be too big for the trick flow kit too. I run a 65mm TB with my edelbrock heads, cobra intake, and TFS 1 cam..
It feels like  cause the air has no velocity now, and all your low end torque is gone now. If you must upgrade the stock non-HO tb just get a stang 60mm and stang upper intake for now...
:iagree: The 75 is huge.Bigger isn't always better.......as you can now see.Get a Mustang 60mm.They're on E-bay all the time for CHEAP.
 i guess im sendin it back then..
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Even on my Trick Flow kit I run a 70 mm TB and THAT's borderline of too big.
The stock SO TB is 50 mm.  Grab yourself a HO 60 mm TB and be done with it.
