Topic: Engine Trouble (Read 2470 times) previous topic - next topic
Engine Trouble
Yesterday as soon as I accelerated I wasn't getting full boost and the engine was feeling real doggy, so I parked it.  Basically it seems like I'm only firing on 2 cylinders and there is a clicking sound coming from the top of the engine.  Any ideas?
Engine Trouble
So how much boost are you getting compared to normal? Also are you shure that the clicking sounds isn't the injectors? double check your timing maybe the belt jumped a tooth.
Engine Trouble
in need of new spark plug wires?
Engine Trouble
double check your oil and oil pressure, make shure they arent low, oil my not be circulating 100% to the top of the engine and the turbo, probably not, but its not something to be overlooked
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Engine Trouble
Ticking huh?? Sounds like its time for a compression check, you may have popped a head gasket...
Engine Trouble
Quote from: tc²;104204
How many miles on it? If you're over 75K, you may need to replace the timing belt. Happened on my '86.  'Cept when it happened it did that for ten seconds then died.
Engine Trouble
The more I think about it sounds like a boost leak. Lower than normal power and doggy. I had a cracked hose on mine. It had py idle and low boost.
Engine Trouble
Do these engines have a knock sensor? if so the top end tic may be sending it false readings.
Engine Trouble
yep they have knock sensor. It is in the lower intake. It is possible to get false readings with it. Just unhook it and go for a ride. If the power is back you are making some sort of noise that is doesn't like.
Engine Trouble
+1 on the head gasket
Engine Trouble
As for all of these issues:
I'm running about 9 lbs under full load as opposed to 11.
Tried new plug wires to no avail, however when I disconnect the wire going to the cylinder closest to the front of the car, the clicking stops.
Oil/oil pressure is good.
Don't think it's a head gasket... no coolant in oil.
Car runs the same with/without KS.
Engine Trouble
You pull the #1 plug wire and the clicking stops?  Does the engine run the same?  What happens when you pull the other plug wires?  Have you pulled the plugs?
Sounds like a dead hole....could be a HG.
Engine Trouble
Yes, that is correct.  The engine runs less rough with #1 plug wire pulled, the rpms rise slightly also.  I have not pulled the plugs.
Engine Trouble
Pull the plugs...that's weird.
Engine Trouble
fouled or bridges sparkplug?
and as i said... time for new wires
