Topic: wont start (Read 3484 times) previous topic - next topic
wont start
I recently installed new plugs and wires in my ho swap i have an 88 sport bird. After that I notice that it would hit the gas and it would hesitate them get a huge kick of power and be normal. the next day i would hit the gas and it would make a loud noise like a backfire. Not at any given moment it will cut off and not cut back on for a couple of hours. At idle the engine would shake tremendlesly then after a while it would calm down. please help wont start at all now
thunder306
Registered User
(10/18/04 9:24 am)
Reply  Re: stalling loss of power
 start using the new board
http://www.foxtbirdcougarforums.com
when you repost this at the new site, include a list of mods so we can better understand your setup. Just off the top of my head double check the firing order... Did you do one wire at a time or take them all off. Are you using the HO firing order with HO speed density or mass air computer
Here's some questions for ya
did you just do the HO upgrade?
did it run good before the tune up?
mass air EEC or speed density?
any CEL or codes in EEC?
what plugs did you install?
where is timing set at?
do you have an adjustable fuel pressure reg?
Bob
Philadelphia
Edited by: thunder306 at: 10/18/04 9:31 am
buffleheadct
Registered User
(10/20/04 10:07 am)
Reply  list of mods
 Custom dual exhaust of each header no h pipe straight back with flows. BBK shortie's,intake,under drive pulleys.
Just did the swap using lsc computer. ran good before the tune up. Using mighty plugs and wires that are too long.
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Re: wont start
Quote from: svtbird
thunder306
Registered User
(10/18/04 9:24 am)
Bob
Philadelphia
buffleheadct
Registered User
(10/20/04 10:07 am)
Reply  list of mods
A buddy of mine removed on of the plugs and stuck a screw driver in it and tryed to start the car no spark?
                        :birdsmily:
Re: wont start
no spark and before that having to wait before it would start suggest ignition module....try running codes
Re: wont start
Kinda sounds like your timing started to slip and maybe you now broke the timing belt/chain.
Re: wont start
got car started ignition control module slipped off. now car has a very lopey idle. And hesitates intermittently. sounds like someone is popping popcorn when i hit the gas?
                        :birdsmily:
