Topic: Will this rims fit? (Read 3552 times) previous topic - next topic
Will this rims fit?
Hey guys will this rims fit on my cougar with the mustang fox diff I would really like to put these wheels on thanks guys lmk. Cragar wheels
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Re: Will this rims fit?
If i'm not mistaken, all the cragar street stars are 5 lug.  They will fit if you swap over to a five lug.  The only wheel manufacturer I know of that makes that "style" of wheel in 4 lug is bogart, and they are WAY more expensive!  Cragar makes a street lite (i think its called?) that looks like the weld superlite that is available in 4 lug.  Hope that helps, it's been a while since i sold wheels! :)
Yea Ill be switching over to 5 lug thanks.
Also I forgot to ask will the rims or wheels stick out? thanks guys lmk.
If it were me, I'd run the 15x8 with the 4 1/8 backspacing on the rear with a 255/60 or a 275/50 sized tire on the rear.  For the front I'd go with either the 6 or 7 inch wide wheels, because the in the 8's they just don't offer enough backspacing.  Nothing should stick out, especially with fox (or ranger) axles.  Hope that helps?
Well I was planning on going with 15x10 on the rear would they fit ok? Also for the front I was planning on going with some 15x8 will these rims fit up front It not Ill go 15x7 what do you think of this setup thanks man lmk.
15x10 as far as i know is too wide
15x9 will clear, seeing as guys here run 17x9's
A 15x10 wheel will fit on the back, but you need around 6 1/2" backspacing, and an 8" will fit up front, but for some reason Cragar only offers those wheels w/goofy backspacing...You can get weld wheels that will fit, but they are polished aluminum not chrome- and a little more expensive.
