Topic: miss fire while drive (Read 980 times) previous topic - next topic
what all could cause a tc to miss fire while driving, when it misses it shakes back and forth pretty bad, i was told it is the stator,  i put sum plug wires on and the didnt help, so gimaa an idea what could be causein this to happen
Does it do it cold? or hot? or both?
What brand of plug wires did you use? What are you running for plugs?
TCs are real finicky about plug wires. About the only ones that work consistently are the stock Motorcraft replacements, E8PZ-12259-A.
Taylor Hi Energy wires work well also. I heard they can be had from Summit Racings. MagnaCores also work well. Just about everything else has caused problems sooner or later.
Plugs are also kind of critical. I like the Autolight 764 coppers gapped around 0.032" Stay away from the platinums and such. You can also use Motocraft AGSF-32CF-4
If your tuneup is getting kind of old (over 12K) or you don't have the right plugs and wires, consider doing those things first and see how it affects your problem.
regaurding plug wires i just put on some ford racing 9mm, plugs im not sure cause i just got the car,  but i am puutin new plugs in the beast, and im doin a cap ,rotor, and stator  so hopeful,ly it will fix the problem
