Ok, here's another question. I've searched around on the Mustang boards and found different opinions, so I figured I'd ask here since I trust you guys the most.
Concerning sealant for the lower intake gaskets, where should I apply it? I plan to use silicone generously for the front and back seals (especially the corners), but am unsure about the side gaskets.
The Fel Pro instructions say none is needed. Some people say apply it around the coolant orifices, and I've seen some people put it everywhere. Opinions?
ok it is a good idea to use rtv on the frount and back of the intake. but be careful to not use too much cuz if it gets into the engine it can cause prsoblems. but for the gaskets just use a little bit to hold the gasket in place. and if you want too it doesn't hurt to put a little bead around the water jackets. Hope that helps ya
