Technical => Engine Tech => Topic started by: flipnbird on June 26, 2006, 10:58:59 AM
Title: roller rockers
Post by: flipnbird on June 26, 2006, 10:58:59 AM
morning guys, any noticeable performance gain by installing 1.7"s on a stock( for now)SD with HO upper, throttle body, true duels stang shorties?? and how about a 65mm throttle body?? would the 65 be to much ?
 Thanks in advance
Post by: V8Demon on June 26, 2006, 03:21:57 PM
The 1.7 rockers are a good addition as you will notice some more pull higher up where the SO motor needs it.  As far as the throttle body I'd go with a 60MM unit from an HO motor.  The 65 MM is not necessary for the combo you have.
Post by: flipnbird on June 26, 2006, 08:19:18 PM
Thank You, I got the 60mm, I was just wondering if the 65 would give me anything or just bog me down( no low end)I got 1.6"s on now and have the 65 in the garage. so I would be able to tell a diff with the 1.7"s?? car runs great now, just felt like doing something!! got the crower 15511, 65mm, 87 SD puter,#19 inj.,bbk fpr waiting to go in this fall, should i wait till then?? yea probably but i was wanting to show my son how to put them on, he is 10 yr's old and buggin the He!! out of me, he is deffinatley going to be a rodder!!!!!!!!!!, ya"ll are great!!!!
Thanks for any more info
Post by: Bird351 on June 26, 2006, 08:35:22 PM
http://www.lincolnsonline.com/forum/showthread.php?t=32558
Look for the post by Bluegrass on the subject.
