Technical => Engine Tech => Topic started by: 88sportcoupe on December 18, 2005, 10:05:53 PM
Title: Oil Pressure sending unit
Post by: 88sportcoupe on December 18, 2005, 10:05:53 PM
Is there a difference in the sending units from a thunderbird to a mustang. My oil pressure gauge reads high almost all the time and it just doesnt seem like it is working properly.
Post by: Thunder Chicken on December 18, 2005, 11:01:41 PM
Ford used a fake oil pressure sender back in the day (and still does). It is not really a sensor, it's a switch with a resistor. Under, say, 15PSI, the gauge will show low. Over 15PSI it will show midwaybin the gauge. This was an (extrememely dishonest) way of reducing uneccesary trips to the dealership (and warranty costs). Mustangs use the same gauge.
What I did to get around it is to use an aftermarket sender - AC Delco, P/N 01972321. It fluctuates with temp and RPM, so it seems to be working
Post by: Nate on December 19, 2005, 03:32:33 PM
Quote from: Thunder Chicken
was that swap fairly straite forward? i noticed a few gauges in all the 88s and 87s i drive being off and was wondering about how to fix it. expecialy on the turbo coupe with its insaine oil pressure. i still need to get a real gauge to check it before i "fix" it tho.
Post by: V8Demon on December 19, 2005, 07:00:10 PM
http://www.foxtbirdcougarforums.com/showthread.php?t=4353&highlight=oil+pressure
This should help...
