Technical => Engine Tech => Topic started by: sum_weirdo on December 03, 2005, 06:17:45 PM
Title: 1 week after the rebuild
Post by: sum_weirdo on December 03, 2005, 06:17:45 PM
Like the title says it's been about a week since my car hit the road again after I finnished rebuilding my 302.  Since then I've put about 150 Km on it and except for an EGR issue that kept stalling it the engine has run fine.  But whenever the car is sitting in traffic I get a really rough sound like a hard thumping that goes away again when I speed up.  It hasn't affected driveability, the engine runs and the transmission shifts fine.  For a while I thought maybe the new cam just roughened the idle but it seems a bit excessive.  Tomorrow I'm putting her up on ramps again and making sure the torque converter nuts are snugged down as well as the engine mounts (the engine mount nuts went on hard, actually one went on easy and the other one gave me 100 Ft-lbs of torque by the time it was halfway on the stud.  I think I might have bent the stud slightly when the engine went in).  Can anyone suggest anything else I should look for?
Post by: 1WLD BRD on December 03, 2005, 10:09:26 PM
Did you check to see if the exhaust was touching the frame anywheres?
Post by: sum_weirdo on December 03, 2005, 10:21:16 PM
Not specifically but I don't think so.  It should be in the same layout as before.
Post by: SirChirpAlot on December 05, 2005, 10:34:21 AM
If its a thud when u go to drive then its some thing shifting.
Odds are its a mount.
next time you drop in a motor keep the motor mounts losse on the block so they flop around a bit and its alot easyer to line them up in the K member that way.
Post by: sum_weirdo on December 18, 2005, 09:06:51 PM
Alright at long last I know what the problem is.  There's a vacuum leak in the brake booster.  You can hear the hissing if you don't have the heater or radio on, sometimes when the pedal is down and sometimes when the pedal is depressed.  Explains a hell of a lot.  Is replacing the booster the only way to go?
Post by: Nate on December 19, 2005, 03:28:23 PM
you might be able to replace the diaphram, but im not sure. i have never taken one appart. eather way im pretty sure your going to have to remove it to fix the problem, its not that hard say for the bolts under the dash. i used long 24"+ extentions for my ratchet.
 if you plan on putting in a 5 speed with a firewall mounted adjustable clutch cable now would be a good time to put in a mustang brake booster with its smaller diameter.
Post by: sum_weirdo on December 19, 2005, 08:13:07 PM
No I'm pretty happy with my AOD.  And I'll be plenty happier still once the vacuum leak is resolved.  Quick question though, is there any actual fluid transfer between the booster and the master cylinder?  If I can I'd like to just leave the cylinder hooked up and sealed.
Post by: SLEEPER T-BIRD 87 on December 19, 2005, 08:19:39 PM
Quote from: sum_weirdo
no there is fluid between the two.If you find fluid the master cyl is probly bad and leaking.
You can just remove the 2 bolt and set it out of the way while leaving the lines connected.;)
Post by: Haystack on December 19, 2005, 08:36:43 PM
Yeah, I have heard the brake booster sucks. Throw in a new master cylinder while you are in there. Its like $10 and a 2 minute job that you will be doing anyways. And then there is always the peace of mind that goes alng with it.
Post by: sum_weirdo on December 19, 2005, 09:40:20 PM
Well I do have a new cylinder kicking around.  If I can get the old one off without destroying the fittings maybe I'll go ahead and do that too.  Thanks guys. :)
