i have changed the comp, coil, ing mod. still have nothing. also checked voltage at coil and that was good. please help.
Take your distributor cap off, have somebody crank the engine, and verify that the rotor is turning. You may have broken a timing belt, and if so you'll have no spark because the distributor won't turn
i dont have a spark leaving coil, timing belt is ok.
ok since you said timing belt i am assuming it is a 2300 turbo
they are bad about eating distributor gears pull the cap off and make shure the rotor turns.
then take a test light and put it in the positive side of the coil (orange or red wire) turn switch over it should light the test light if it does you have a tfi problem possible wiring
yes it is 2.3l. i do have voltage at postive term. on coil. 9.87volts at coil. i also changed the dist.
it should have a full 12v at the coil
sounds like a wiring issue that you have. between the tfi module and the computer
i will check that. thanks. will check in fri.
