Technical => Engine Tech => Topic started by: cougarpower51 on September 18, 2005, 11:28:51 PM
Title: 3.8 problem
Post by: cougarpower51 on September 18, 2005, 11:28:51 PM
When Im on a stop light my cougar turns off, what can the problem be, its only when i stop, if im cruising on the highway no problem and its and 88 cat 3.8 :america:
Title: Re: 3.8 problem
Post by: Chris1987LX on September 22, 2005, 12:01:47 AM
Cat. converter.
Post by: vinnietbird on September 22, 2005, 06:48:35 AM
When I had my 3.8 in my '88 Bird,i hollowed out the cats,added dual exhaust with nice Turbo lers,and it was great.It ran stronger (power you could actually feel).She has 5.0 power now,which,in my opinion is one of the best mods you can do to a 3.8..........swap it.
Post by: cougarpower51 on September 23, 2005, 12:25:56 AM
I gutted the cat converters :flame:  :sorry:
Post by: cougarpower51 on September 23, 2005, 12:27:24 AM
I forgot to mention they where gutted about a year ago, its the first time it did this
Post by: V8Demon on September 23, 2005, 11:21:58 AM
Could be any number of things......IAC, ignition module, TPS........... When was the last time you gave it a good tune up?  I had an old car that would cut out on idle only when it was wet or raining out.......The cause?  Distributor cap had a HOLE in it.
Post by: Chris1987LX on September 25, 2005, 09:16:12 AM
Gutting the cat is one of the worst things you can do.  There's that one steel line running from the cat into a sensor near the pas. side exhaust manifold that monitors the exhaust. That might have failed.
