Technical => Engine Tech => Topic started by: 86Tbuzzard on August 12, 2005, 02:57:03 PM
Title: EFI or Carb
Post by: 86Tbuzzard on August 12, 2005, 02:57:03 PM
hey guys, I got a question and I'd like your opinions...Should I convert to HO intake, computer, MAF, injectors, or should I go to a 6 pack or dual 4bbl setup? A guy that I know builds carb kits for like 1500...
Title: Re: EFI or Carb
Post by: Chuck W on August 12, 2005, 03:12:57 PM
Efi
Post by: 86Tbuzzard on August 12, 2005, 03:38:05 PM
Quote from: Chuck W
Efi
 what do you think it'd cost to do a SO intake to a HO MAF setup?
Post by: 86Tbuzzard on August 12, 2005, 03:38:44 PM
oh one more thing...how can ya tell what size your injectors are?
Post by: 88SptCoupe on August 13, 2005, 10:17:00 AM
14lbs are grey in color 19 lb orange or tan color
Post by: Tbird232ci on August 13, 2005, 11:08:58 AM
Quote from: 86Tbuzzard
6 pack and a dual quad is much more carb than your 302 would ever need, while it looks cool, the car would run like ass
just go with an HO setup, stuff is only as expensive as youre willing to, its not hard to find stock HO stuff
Post by: 5.0willgo on August 13, 2005, 11:10:06 AM
You really won't have to go to mass air. That is unless you do the full H.O. conversion to your existing motor or swap in an existing H.O and do significant modifications. If the motor is going to be basically a stock H.O., it will run fine on speed density.
Heres the info on converting your existing motor to H.O.
http://www.coolcats.net/tech/advanced/ho_conversion.html
Post by: SLEEPER T-BIRD 87 on August 13, 2005, 04:46:16 PM
i would suggest going with a carb
a holley 600 vac secondary and a preformer or performer rpm intake will work just fine on a mild 302
Post by: 86Tbuzzard on August 13, 2005, 05:19:31 PM
Quote from: 88SptCoupe
all grey or just the tops of them?
Post by: 86Tbuzzard on August 13, 2005, 05:21:46 PM
Quote from: 5.0willgo
it's gonna have a cam, maybe a Supercharger in the future...I'd better go with MAF
Post by: 88SptCoupe on August 13, 2005, 10:02:14 PM
the 14 ones are all grey the 19 lbs are orange and tan if you need a pic of the 14 lbs once i can get you it
Post by: 86Tbuzzard on August 14, 2005, 02:36:20 PM
might be helpful...mine are grey but I think part of them are orange
Post by: 88SptCoupe on August 14, 2005, 04:37:23 PM
http://cgi1.ebay.com/aw-cgi/eBayISAPI.dll?ViewItemWithCategory&item=7985993605
here is the set of 19 lbs fuel injectors i got
Post by: 86Tbuzzard on August 16, 2005, 06:00:04 PM
yeah they're 14 lb injectors
