Technical => Drivetrain Tech => Topic started by: Moonmount on January 21, 2017, 11:56:30 AM
Title: Axle bearings
Post by: Moonmount on January 21, 2017, 11:56:30 AM
Alright so I ordered timken fc66998 bearings as they said they're the correct part but they're definitely not way too large what's the correct bearing for the rear axle?
Post by: Aerocoupe on January 22, 2017, 09:51:03 AM
A little info on the rear end they are going into please.
If it's an 8.8 or 7.5 then a BCA 5707 is what you want.
Post by: CatWoman on January 31, 2017, 04:16:14 PM
Where is the rear wheel bearing located on my 86 Cougar?  Is it behind the hub?
Post by: Haystack on January 31, 2017, 07:24:39 PM
Behind the axle.
You have to drain fluid and pull the c-clips in the diff before you can pull the axle. Then you need a tool to remove and press in the new one into the axle tube.
Post by: Aerocoupe on February 01, 2017, 02:39:36 PM
Pretty decent video showing how to replace the rear axle bearing and seal.
https://www.youtube.com/watch?v=VXEqzMVRRso
Post by: CatWoman on February 24, 2017, 03:09:59 PM
So I have a lot of rear end noise in my car, it's driving me nuts so I'm having the bearings replaced,  is there anything else that would make a lot of roaring noise other than tires?
Post by: Aerocoupe on February 24, 2017, 04:40:15 PM
Let's start another thread to address any issues other than the axle bearings and seals.
Post by: Haystack on February 24, 2017, 07:51:59 PM
Lots of things can make road noise. Anything that moves.
