Technical => Engine Tech => Topic started by: 3Deuce64 on June 28, 2005, 09:00:13 AM
Title: 93 super coupe
Post by: 3Deuce64 on June 28, 2005, 09:00:13 AM
skip  no  fire on  # 2  new  injectors ,plugs, wires , coil pack, 150 lbs  comp.  noid  light flashes  12  volts  on  red  wire no resistance to  the  other wire  on    the  connection  of  #  2 injector the trigger  wire  to  complete  the  circut.  Bad  harness ???  or  bad  comp
Title: Re: 93 super coupe
Post by: TurboCoupe50 on June 28, 2005, 11:54:46 AM
Could be either... You could check the resistance on the wire back to the EEC to verify its circuitry. Or check at the output of the EEC(pin #59 for cyl #2) with the noid to see if it is firing.  Since we don't deal with the Super Coupes, your best bet would be to check with these guys....
http://www.sccoa.com/
