Technical => Engine Tech => Topic started by: Herbsbird on October 03, 2013, 07:51:27 PM
Title: No start on my 86 5.0 Bird.
Post by: Herbsbird on October 03, 2013, 07:51:27 PM
As a new T Bird owner, I have had a problem with Starting and rough running. Finally found out the problem. Distributer module. Purchased a new one and the car started and ran but not well. Found the original Motorcraft module in the trunk and installed it. The car has been running fantastic until today. Wouldn't start again! After checking out everything else, I pulled the distributer and swapped the module for the one that I had purchased before (It didn't run well then). Now it starts and runs pretty well. Note: the new module that I purchased was not Motorcraft. It was a Borg=Warner. Has anyone else had these same kind of problems? Seems to be a weakness or maybe it is just my Tbird. I think that I am going to try and find a new Motorcraft module. Herb
Post by: TOM Renzo on October 03, 2013, 08:31:17 PM
You need to change the PIP!!!
Post by: TOM Renzo on October 03, 2013, 08:32:42 PM
You need to change the PIP along with the TFI !!! If you want to get fancy remote mount the TFI modulet!!
Post by: jcassity on October 03, 2013, 10:07:56 PM
Actually you need to pull the codes and stop shotgunning problem so maybe we should back up a couple steps
When the TFI module is changed it doesn't care spark problems is highly likely the peppers next But the right thing to do is pull codes first
All you need is a paperclip to do it
Instructions in the diagram is in my  DIY link below
Post by: Herbsbird on October 03, 2013, 10:17:24 PM
Thanks guys, I will try to pull the codes tomorrow.  I never had a car with these kind of problems. I've always had old cars with basic simple to diagnose stuff. I'll let you know how I make out tomorrow. Thanks again. Herb
Post by: Haystack on October 03, 2013, 11:57:44 PM
http://sbftech.com/index.php?topic=588.0
solve it in 20 mins if you have access to the required tools.
Post by: jcassity on October 04, 2013, 01:15:56 AM
I've never really great but the process because you end up moving your timing to include this in your troubleshooting
It's not really that big of a deal though
Post by: TOM Renzo on October 04, 2013, 06:19:39 AM
I have a ONE SECOND TEST PROCEDURE STACKS. Jay that is why i have a spare known good  DIZZY in my tool box. Remove the plug from the cars TIF plug it in to the test DIZZY key the ignition and spin the shaft with your fingers. (NOTE it does not have to be a dizzy of the same cylinders. For example yopu can use a 4 cylinder dizzy to check a 6 or 8 cylinder engine) If you have spark you know where the issue is. By the way Jay you do know that the DIZZY makes spark without the ECM even being hooked UP!!! So codes are a MOOT ISSUE!! THE TIF dizzy works void of the ECM. So if he is having ignition issues codes do not MATTER!! If he has a drivability issue he needs to pull codes that is a GIVEN.
Post by: Haystack on October 04, 2013, 08:26:30 AM
I always just marked current position on the distributor with a sharpie(just draw a line from the base to the timing chain cover) then I loosen the dist bolt and rotate it by hand with the key on engine off.  no need to remove the dist if its not the problem, then you just line it back up to your mark and your done.
Post by: jcassity on October 04, 2013, 10:03:47 AM
clever idea there tom~!
the op has enough to start with but ill add this comment.
ever stripped down the stator or PIP to see whats in there?
my conclusion on two defective ones all came back to one common point.
the black wire bonds to the mounting braket with an electro weld / solder joint.
both failed stators were corroded and one was actually disconnected.
they parallel the black wire as it transitions to the molded female spade connector such that a pig tail branches off and bonds to the mounting braket of the stator.
ive often wondered if it would not be best to imply cut the black wire on the stator and ring lug it inside the dizzy directly to the mounting braket so the ref ground can be easily managed.
ive got pics of one of these i disected
Post by: Herbsbird on October 04, 2013, 10:49:37 AM
Tried to pull codes using the service light on the dash. Nothing. Then hooked up a test light to the output and I did get only one code. (1 1)  I guess that means that everything is O.K.. The car is running O.K. now but I'm going to keep my fingers crossed. I did notice that the tfi module is very hot but that may be normal. we will see! Going to a car show tomorrow and hopefully we will be alright. Only about 20 miles away. Tom said to change the PIP. What is that? Herb
Post by: TOM Renzo on October 04, 2013, 09:51:28 PM
http://www.google.com/imgres?imgurl=http://z.about.com/d/autorepair/1/0/O/W/42295558.gif&imgrefurl=http://autorepair.about.com/library/a/1i/bl062i.htm&h=371&w=350&sz=21&tbnid=1zlgLgjFpu4YPM:&tbnh=114&tbnw=108&zoom=1&usg=__SQn62EZLaYjzxySKFdPpiqVqqJk=&docid=kTC01VRNOZtJMM&sa=X&ei=eHBPUpTkF6zc4AO2uYC4Aw&ved=0CEEQ9QEwCQ
Post by: Herbsbird on October 04, 2013, 10:36:03 PM
Tom, I see, said the blind man when he picked up the hammer and saw!! Thanks again for your help. Learn something every day. Herb
Post by: Haystack on October 04, 2013, 10:57:11 PM
http://m.youtube.com/watch?v=9QSiS6wf7oU&desktop_uri=%2Fwatch%3Fv%3D9QSiS6wf7oU
copied the mobile link, but this is me running a key on engine running test on my 87 bird.
Post by: jcassity on October 05, 2013, 11:17:16 AM
here is whats going on inside the stator i described earlier.... old thread pic from 2007
the uninsulated jumper shown consisted of about 6 strands of solder tinned copper.... 4 of which were corroded and open.
