Technical => Engine Tech => Topic started by: wayfastwhitey87 on May 24, 2005, 07:33:06 PM
Title: Pcv valve ?
Post by: wayfastwhitey87 on May 24, 2005, 07:33:06 PM
hey guys i have a 87 xr7 with the Ho coversion, E303 cam.  i what fooling with the intake manifold and i pulled the thing out that sits in the back of the lower manifold.  i when to a car store and got a new pcv valve put it is to small.http://www.partsamerica.com/ProductDetail.aspx?mfrcode=FRA&mfrpartnumber=FV198&parttype=5&ptset=A
  do i have to get a grommet or something.http://www.partsamerica.com/ProductDetail.aspx?mfrcode=RNB&mfrpartnumber=42327&parttype=738&ptset=A
your help would be appreciated!
Title: Re: Pcv valve ?
Post by: bondocougar on May 24, 2005, 07:45:30 PM
Yes, you need both of those.
The grommet fits snug in the lower intake and the valve goes into it.
Note the PCV valve is a universal fit.  For that engine  you cut the segment with the two horizontal tubes in the picture off so you are left with just the base tube sticking out.
Post by: Bird351 on May 24, 2005, 07:56:58 PM
Cut off? You might just be able to pull that F-shaped plug off. Yeah, I had to do that when I replaced the PCV on the '88. (pull off the F-shaped part, that is)
Also replaced that filter underneath the grommet as well.. you might want to do that while you're messing around back there.. but if you manage to get it out without mangling it too much, you could probably just clean it in paint thinner or something. If not, it's a $5-6 part at Advanced. A long (like 3") wood or drywall screw works wonders.
Post by: nirvanagod on May 24, 2005, 08:05:12 PM
So here's a dumb one. Does anyone have a decent picture of exactly where that metal filter piece is? I've continually heard about it and the general where-abouts of it's location, but an actual pic may come in handy for future reference.
Post by: Bird351 on May 24, 2005, 08:09:10 PM
I'll try to take one tomorrow if one doesn't appear by then. I still have the uppers off both 5.0s.
Post by: nirvanagod on May 24, 2005, 08:18:29 PM
Quote from: Bird351
 If you can, do a somewhat close one and a pulled back one. That would help with knowing the placement in relationship to other identifiable parts in the engine bay. TIA
Post by: Bird351 on May 24, 2005, 08:28:28 PM
I'll do what I can within limitations of space under the hood, lighting, and py camera. :hick:
Post by: 5.0willgo on May 24, 2005, 11:34:51 PM
It may be more helpful to see it's location with a manifold on the car but here it is from one of the manifolds I have laying around.
(http://img226.echo.cx/img226/1745/pcv18kz.jpg)
(http://img226.echo.cx/img226/9061/pcv26ww.jpg)
The filter is way down in there so it may be best to use narrow needle nose pliars to get it out. Sorry, the filter is not in this manifold so I had to draw it in.
Post by: Bird351 on May 24, 2005, 11:38:11 PM
Tangent time!
Does that little square-headed plug in the lower left corner lead to a water passage? Can it be used for a sender, if so?
Post by: 5.0willgo on May 24, 2005, 11:43:04 PM
I think so. I don't see why it can't be used for a sender but good luck getting that little square-headed plug out. They seem pretty much welded in place. I was going to use them to plug my new manifold so I wouldn't have to buy plugs but couldn't break them free.
Post by: Bird351 on May 25, 2005, 08:43:26 PM
This is the best I could do today. I only remembered it about 5 minutes before I had to leave the house for a couple hours. By the time I got back, it was threatening to rain and it was pretty dark from the clouds.. so not much chance there.
My upper intake is off, my injectors are removed, and the fuel rail is just laying on top of the lower intake.. so that's why the pic might look a little odd.
This probably isn't very useful, with the manifold pictures already posted.. but I said I'd post a pic so here ya go. If you still need clarification tomorrow I can see about a better pic.
Post by: nirvanagod on May 25, 2005, 10:59:07 PM
Pretty much exactly what I was looking for. The 3 pics are a big help in  making locating that infernal part a quick task. I already ordered the part from the dealer so hopefully I can get it in over the weekend. Oh, something tells me this is greatest hits/sticky material  ;)  ;) !!!!!!!
Post by: Bob on May 25, 2005, 11:27:12 PM
take your little propane torch to it get it nice and hot and put a wrench on it... it will turn..
Post by: nirvanagod on June 08, 2005, 09:50:57 PM
Figured i'd get a pic up of a comparison of what a bad and good "crankcase breather filter looks like". Also got the box with motorcraft part # on it in the pic as well. The guy at the dealship ordered the right part name the last time, just got the wrong #.
Post by: nirvanagod on June 08, 2005, 09:55:19 PM
And while i'm at it i'd figure i'd throw and epiphany i've into the mix. Looking at one of the pics bird351 posted (and I borrowed for visual reference sake). Does the pcv valve actually sit in the gromet for the breather filter? From this pic it sure does look like it. If that's the case, what problems could this potentially cause? I know the clogged crankcase filter can blow lower intakes gaskets, but not sure about what not having things connected up right would do?
Post by: Bird351 on June 08, 2005, 10:11:09 PM
Don't know.. but one observation:
Motorcraft oil filters are supposedly made by Purolator.. so I don't see it being a stretch that those crankcase breather filters would also be made by Purolator. That looks identical to mine, and I picked up a Purolator. (of course, how different could they look?)
Point is.. in cases where it's easier for someone to go to a parts store that has the Purolator in stock vs. going to a dealer or another store for the Motorcraft version, maybe they should consider just getting the Purolator. Part #B15231. ("To Reorder, Specify B15231M", just to list everything it says on here.. did not get a good picture of it)
Post by: nirvanagod on June 08, 2005, 10:31:06 PM
Well I only paid like 5.90 plus tax for the motorcraft one from ford, and since the dealer is right down the street I figured why not just get it from the source. As for checking the retail chains, I can't say i've ever seen that part in my searches. I also bought the motorcraft pcv valve while I was at it, and I can say that there is a significant difference between it and the purolator part. I'm really curious to know how much  not having things plugged in right could caused (i.e.: oil all over, bad idle etc. etc.)
