Technical => Misc Tech => Topic started by: comonstone on June 22, 2010, 07:53:03 PM
Title: only allows me to reach low rpm
Post by: comonstone on June 22, 2010, 07:53:03 PM
i have tried changing the cap rotor tfi plugs wires an catilatic converters still imy 88 cougar ls with a 5.0 in it only allows me to reach about two grand an then she spitts an spuders an sometimes kills what do i do an theres not ten thousand on the fuel pump an changed the fuel filter any ideas what else
Post by: hypostang on June 22, 2010, 08:24:26 PM
Quote from: comonstone;326241
Is it throwing any codes?
Post by: Haystack on June 23, 2010, 01:07:04 AM
I would do the coil, and check your spark plug gaps and wires. v-8's still run okay if you have the wires clocked one over until you put it under load. I would also pull codes.
