Technical => Drivetrain Tech => Topic started by: Dutch on October 12, 2009, 11:38:54 AM
Title: Wierd Air Sound
Post by: Dutch on October 12, 2009, 11:38:54 AM
I just got an 83 T Bird and there is a wierd air noise that is louder when in park that is comming out from under the dash. When you put her in gear it is still there but not as loud. It is not a vacume leak the car runs great. Any suggestions as to what it is?
Dutch
Post by: jrad235 on October 12, 2009, 12:27:26 PM
It could still be a vacuum leak, is your 83 carbureted? When mine is running rich, and I pull a hose, the idle picks up and it runs better. Do all your vents and such work properly?
Could you at least describe the sound?
Post by: MasterBlaster on October 12, 2009, 01:20:06 PM
4 common causes:
Vacuum pipes or parts for the heater controls.
Cruise control release valve at the brake pedal (if equipped).
Automatic parking brake release (if equipped).
Turbo boost gauge hose (but you don't have one).
Post by: EricCoolCats on October 12, 2009, 01:29:13 PM
Also...could be a bad brake booster. When that happens there is a constant hissing under the dash, and when apply brakes you can hear it get a little louder. Also the hissing would change depending on whether the car is in Park or Drive, as described.
You'll probably need to stick your head under the dash with the car running and in Park, and try to pinpoint the location of the hissing a little better. That way we can help troubleshoot with more certainty.
Post by: 86caprirs on October 12, 2009, 09:37:00 PM
I also had a customer come in for a hissing noise from the dash. Turned out one of the rubber plugs on the firewall was pushed off and missing.
Post by: jrad235 on October 13, 2009, 02:22:40 AM
Quote from: 86caprirs;294579
But that was a "while driving" complaint wasn't it? My take is that Dutch is sitting at idle.
Post by: Haystack on October 13, 2009, 04:46:43 AM
mine does it only in 2nd and not at all in any other gear. Something I oughta look into, but not a big deal.
Post by: Dutch on October 14, 2009, 05:47:42 AM
[COLOR="darkorange"]4 common causes:
Turbo boost gauge hose (but you don't have one).[/COLOR]
[COLOR="Black"][/COLOR] Ok here we go
Cruise control this has been diconnected
Automatic parking brake, Don't have that
Turbo boost gauge hose, Don't have that
Heat I don't have that as of yet replace the thermos stat yesturday due to the one in her wasn't opening and the new one isn't opening either it is a 160 degrees not under that one at all either.
Removed the Compleat A/C system and clutch fan all together, Installed an electric fan system with a manuel controll switch and the thermos stat still wont open.
So now the noise is still there and the heat don't work. We (my son and I) were all over this thing and still can't find where the wierd noise is comming from. Sitting idle or driving the noise is there.
This car is a 5.0 with an 8.8 rear and AOD.
I know there is a vacume leak under the T/B bottom gaskit but you can't hear that from inside the car or under the hood, it is the way she idles that we know of the T/B gasket leak (it speeds up when checking with starter fluid sprayed at the bottom of the T/B were it meets the intake.
While here does anyone have a front right hand turn signal lens? I know 1983 to 1986 will fit.
Thanks in advance,
Dutch
Post by: Haystack on October 14, 2009, 07:39:10 AM
Are you running EFI, or Carbed? If your running EFI, don't even bother with a 160 stat. I just threw in a 192 on my 87. The old one was in pieces I dug out of the lower intake. And just because your heat isn't warm dosen't mean it isn't working. The heater vents can be computer controlled. Other people are fishing for more information, and have given you quite a bit considering what you posted.
Post by: jrad235 on October 14, 2009, 02:54:49 PM
Well, the vents in an 83 are Vacuum controlled, except for the blend door, so is the upper radiator hose physically getting warm? Or are you just judging the temp by inside the car at the vents?? From the sound of it, it could still be a vac line/s from the HVAC vents.
Post by: softtouch on October 14, 2009, 05:46:04 PM
Take the hoses off the vacuum tee one at a time to find the one causing the noise. Let us know what you find.
Post by: Dutch on October 15, 2009, 09:16:29 AM
The hose on the top gets ahrd and very very hot can't even hold onto it, it gets so hot!!! Go to remove the radiator cap and the antifreeze comes out wich tells me the thermos stat is not opening. I went to Car carft yesturday and got a 195 stat and going to put that one in today hoping the one I installed the other day was just a bad one. I have a Throttle Body fuel system and I know there is a vacum on the bottom gasket that needs my attention.
Post by: Dutch on October 15, 2009, 09:20:32 AM
The hose on the top gets hard and very very hot can't even hold onto it, it gets so hot!!! Go to remove the radiator cap and the antifreeze comes out wich tells me the thermos stat is not opening. I checked the normal blown headgasket systems and ther is nothing in the oil but oil.  I went to Car carft yesturday and got a 195 stat and going to put that one in today hoping the one I installed the other day was just a bad one.
My fuel is a Throttle Body system with a leak on the bottom gasket that I know I have to address
Post by: Haystack on October 15, 2009, 09:25:59 AM
make sure you put the spring twoards the block. If your worried about it opening, make sure you test it by throwing it in boiling water first.
Post by: Dutch on October 15, 2009, 12:20:53 PM
Seems the thermos stat is opening because the heater hoses are getting hot too but still no heat, must be a vacume leak some place. Will the bottom gasket on the throtle body that is leaking cause the heater vacume not to work?
Post by: jrad235 on October 15, 2009, 03:04:36 PM
How are the brakes? Is the pedal very hard to push while the engine is running? Or does it seem to have some vacuum assist? I believe the heater components need a certain amount of vacuum, measured by "In Hg" If I recall correctly, but not sure what the number required is. A healthy motor should pull at least 15 In Hg of vacuum at idle, or more. Do you have a vacuum gauge?
Post by: Whiteboy on October 16, 2009, 03:26:41 AM
I'm having the same problem with my new 88 I just got, and the cruise doesn't work on it. The hissing noise stops when I take it out of park...
Post by: Dutch on October 28, 2009, 12:31:48 AM
Ok guys I got the heat working now but the air noise is still there. I am sorry it takes me awhile to get back to you all but I am trying to get the money to get the things I find the car needs so I can fix them before I say the problem has been repaired. So the vacum moduel under the dash for the heat was not working. I went to the dealer and got into a heated discussion with them over the throttle body base gasket. They tried to tell me there was never a 5.0 in the 1983 bird. So I ran the numbers and took the printout from the Ford Motor Manufacture with all the specs and showed them they have no idea what they are talking about. So I have decided not to talk to them about the noise I hear comming from under the dash. It is like a loud hissing noise that just quiets down when put into gear but does not go compleatly away. I have had many many cars over the years and have never had one do this.
Do you guys have any more suggestions or do like my dad use to tell me whne something was not right, "Just turn up the radio"? LOL
Thanks again for your help
Dutch
Post by: Haystack on October 28, 2009, 04:40:57 AM
Like they said, pull some vaccumm lines one at a time and plug them. That will let you know which hose is making the noise. Check out this diagram
http://www.veryuseful.com/mustang/tech/engine/images/88Stang5.0Vacuum.gif
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxFordVacuumDiagram.jpg
