Technical => Engine Tech => Topic started by: 87tbird302 on April 02, 2005, 08:31:38 PM
Title: help please...
Post by: 87tbird302 on April 02, 2005, 08:31:38 PM
Seems like everytime I give it gas or when it is at a certain RPM (around 1300- up) it makes a popping noise coming out the rear exhaust. Im not sure what it could be. Also when i reved it, some liquid came out of the exhaust and it was black, nasty looking. Could it be because I haven't started it up in a while or what? not sure what it could be. anyone got any ideas, please feel free to post. Thanks.
Title: Re: help please...
Post by: tbirdscott on April 02, 2005, 08:48:21 PM
Water in your gas, condensation from sitting probabally.
Post by: 87tbird302 on April 02, 2005, 08:52:58 PM
what should I do to solve the problem?
Post by: V8Demon on April 02, 2005, 11:29:15 PM
1. Drain it (Probably your best bet)
2. Fill the tank up all the way if it is not (to dilute it some) then drive her till emptyto get rid of as much as possible(something I would advise against)
Post by: vinnietbird on April 03, 2005, 06:41:14 AM
Stabil.It's an additive designed to remove water from your fuel.
Post by: V8Demon on April 03, 2005, 09:44:05 AM
Vin,  I've never tried that Stabil stuff?  Do you know how it works?
Post by: shame302 on April 03, 2005, 11:35:03 AM
dry gass might help. motorcycle shops have good stabilizer. a little goes a long way. it works pretty much like dry gas..
Post by: phyxius on April 03, 2005, 12:59:04 PM
if you feel really cheap moth balls work also,an old racer showed me.
Post by: 87tbird302 on April 03, 2005, 03:54:17 PM
does anyone else think it could be anything else besides water in my gas?
Post by: vinnietbird on April 03, 2005, 08:18:32 PM
The Stabil works great at removing water,and that's exactly what it's designed to do.Just follow the instructions on amount to use,and off you go.
Post by: 87tbird302 on April 04, 2005, 09:36:15 PM
But what would make my exhaust make a popping noise when I rev it a little?
Post by: 87 3.8 CAT on April 04, 2005, 10:26:32 PM
I'm thinking water also.
Phyxius, I was also told to use moth balls to help it run cleaner. Never tried it, but found it interesting to hear someone else say it.
Post by: 87tbird302 on April 05, 2005, 09:02:40 PM
I've never heard of using moth balls, has anyone here tried it and has satisfactory results?
Post by: Bird351 on April 05, 2005, 09:15:20 PM
Googled "mothballs gasoline" and got this so far:
http://www.newton.dep.anl.gov/askasci/chem00/chem00485.htm
That led to this link:
http://www.georgenitta.com/mothballs/mothballs.htm
Note that the topic in question for most of this is using certain types of mothballs for octane boosting, not for water.. but on the second link it DOES mention something about treating water in gas.
I'm not endorsing this stuff by linking to it.. take it for what you will. Personally, I don't think I would try any of the above unless I heard a LOT more feedback in support of it.
Post by: 87tbird302 on April 05, 2005, 09:20:44 PM
ooooooooh no im not going to do it, i was just wondering if people on here actually tried it. I'd rather stick with stabil.
Post by: jcassity on April 05, 2005, 09:53:12 PM
I remember seeing an episode on myth busters about using mothballs,, but it was for increasing the octane of the fuel. It worked!!!  those are some purdy smart guys and if they notice a power difference , im sold.  as for removing water, not sure.
on to your original questions.....
a joint in your exhaust system may have a small enough leak to and may cause some backfire.
you might have issues with gaskets like up at the heads where your sucking air.
as for the water,, like said just deal with it but if and run it good to work out the moisture.  If your loosing coolant, now thats a different story.
